Optoma HD131X : Cheaper black version of the Optoma HD25 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 03-14-2013, 05:08 AM
gofmarat's Avatar
Originally Posted by kraine View Post
I prefer the RF 3D picture thanks to the contrast. With DLP-LINK the white or red synchronisation flash is disturbing.
Great, thanks for your help.
gofmarat is offline
post #32 of 43 Old 03-15-2013, 08:46 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
kraine is offline
post #33 of 43 Old 03-15-2013, 09:39 AM
gofmarat's Avatar
Kraine, thanks for the review.
Are there special settings for 3d mode (color calibration) or it is the same as the 2d?
I see now that on your site, you give this projector 4 stars while the benq w1070 you give 4.5 stars, do you consider the benq as a better projector, if not can you explain the higher score?
gofmarat is offline
post #34 of 43 Old 03-15-2013, 09:58 AM
urbeenjammin's Avatar
Quoted: 66 Post(s)
I have bought the HD131X for my own, it's not only a presssample model, so I made my choice wink.gif
Hello.I wanted to know your thoughts on the flickering issues or problems with the optoma HD25 or HD131 since it doesn't have any triple flash 144hz or image interpolations. I'm thinking of getting one mostly for 3D.I'm stuck between these models or the Benq w1500 which has triple flash and interpolation but deals with dlp link only for 3D.I know how much you recommend the RF for 3D.so I would appreciate your opinion and thoughts.
urbeenjammin is offline
post #35 of 43 Old 03-16-2013, 12:12 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
In my Opinion the HD25 and the HD131X are also tripleflash compatible, like the W1070 120hz DLP LINK 3D Glasses aren't working, only 144hz Glasse are compatible.
The BenQ W1070 has better score because out of the box the colors are more accurate and he is also quieter than the HD25/HD131X.
kraine is offline
post #36 of 43 Old 03-16-2013, 12:48 AM
gofmarat's Avatar
Originally Posted by gofmarat View Post
Kraine,
gofmarat is offline
post #37 of 43 Old 03-16-2013, 03:20 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
I'm using factory 3D settings, I didn't calibrate the 3D picture, only the 2D.
kraine is offline
post #38 of 43 Old 03-16-2013, 04:17 AM
Quoted: 66 Post(s)
so flickering is not a problem with the HD25 or HD131X.
thanks for your input and it seems that the RF glasses gives the Optoma an edge for 3D which is what i'll be using the projector mostly for.
post #39 of 43 Old 03-21-2013, 03:36 PM
Quoted: 66 Post(s)
any updates?
post #40 of 43 Old 03-22-2013, 03:30 AM
gofmarat's Avatar
I'll be receiving it around the 4th of April. I'll update as soon as it arrives
gofmarat is offline
post #41 of 43 Old 05-14-2013, 08:59 PM
Cowboys's Avatar
Liked: 107
You must like it enough to own it. Is it better than the Benq W1070? Thanks
Cowboys is offline
post #42 of 43 Old 06-13-2013, 08:01 AM
mattlocked's Avatar
Hi everyone,
My HD700x died yesterday and I'm out for a replacement. The problem I have is that I invested some money on a 3d-XL adapter and three optoma 3d glasses (DLP-Link) and I need to be able to continue using these.
I'm almost sold on the hd131x but I wonder if I will be able to use my three dlp-link glasses directly or I will need another accesory, as I assume the 3d-xl will be of no use here.
Other problem I might have is that I my projector is mounted on the ceiling and the HDMI cable is v 1.3, so a direct connection to a 3d source might be a problem. I have this sorted out with the 3d-xl which is next to my output devices connected with 1.4 hdmi cables, but the output from the 3d-xl to the projector is 1.3.
I will appreciate any advice or information about this projector and how will it fit my needs and constraints.
Regards.
Matt.
mattlocked is offline
post #43 of 43 Old 06-14-2013, 05:38 PM
mullet34's Avatar
Is this a European-only model? I don't see anyone in the US selling it and it certainly isn't $300 cheaper than the HD25.
Amazon UK has it for $160 more than the HD25
mullet34 is offline
Optoma Hd25 Lv 3d Home Theater Projector
