Looking for low budget, extremely bright projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-06-2013, 02:27 PM - Thread Starter
yanathin's Avatar
Long story short, I'm looking to project something onto a frosted glass panel in a room with a good amount of ambient light. It doesn't have to be 1080p - 720p is okay. I just need it to be super bright. Any suggestions? Thank you!!
yanathin is offline
post #2 of 3 Old 03-07-2013, 06:20 AM
jnabq's Avatar
Liked: 39
You might start at, http://www.projectorpeople.com/resources/bp_buyersguide.asp and http://www.projectorpeople.com/resources/lumen-guide.asp to get a better idea of just how many lumens you might be needing for that application. Then compare that to what you can afford to spend. I think your looking at something around 3500 lumens at least. You could call AVS here to see what they might recommend.
jnabq is offline
post #3 of 3 Old 03-07-2013, 09:08 AM
derek's Avatar
Optoma GT750e...720p 3D with 3000 lumens spec'd; $640 from Amazon
Derek
derek is offline
