Have 5 year old Sanyo Z5, how much better are new projectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-14-2013, 08:37 PM - Thread Starter
HendersonD's Avatar
Five years ago I built a home theater in my basement, here are the details:
http://www.avsforum.com/t/959871/spacesaver-theater-is-done
I have a 110" diagonal SMX acoustically transparent screen with a Sanyo Z5 projector that is 5 years old. I have not been following projector technology closely but if there have been big improvements in the past 5 years, I would look to purchase a new projector.
Would a new projector in the $2,000 to $3,000 range be a big step up from my Sanyo?
The Sanyo is 720p so just jumping to 1080p might make a difference
Most of my viewing is Blu-ray discs
HendersonD is offline
post #2 of 8 Old 03-14-2013, 08:42 PM
jnabq's Avatar
Liked: 39
I'd say significant improvements, 3D, blacks, brightness, maybe quieter, longer lamp life hopefully, and the move to 1080p is almost reason enough alone. A good starting place to get reacquainted, http://www.avsforum.com/t/1391476/coderguys-top-projector-picks
jnabq is offline
post #3 of 8 Old 03-15-2013, 03:48 PM
leckian's Avatar
It is not difficult to notice the increase in detail and sharpness when you move from 720P to 1080P, especially if you primarily watch blu-rays. Depending on your viewing distance you may perceive a smoother more seamless image because of the increased resolution. Depending on what projector you select the improved black level, especially when watching dark movies will be a big wow factor. In your price range you can afford an entry level JVC like the RS46 which will blow you away compared to the Z5.
leckian is offline
post #4 of 8 Old 03-15-2013, 04:21 PM
coderguy's Avatar
Quoted: 307 Post(s)
Liked: 273
It will be a VERY huge and monumental difference coming from an old Sanyo z5. I owned a Z5 a long time ago, almost any new projector (even sub $800) will beat the Sanyo now. Even the $900 Benq w1070 would be a huge step up over the Sanyo z5.
Access HERE from this thread
coderguy is offline
post #5 of 8 Old 03-16-2013, 10:28 PM - Thread Starter
HendersonD's Avatar
After reading through a few threads, it appears that a new projector would be a big jump over my current Sanyo Z5. After about 3 hours of research I think I have narrowed it down to:
JVC DLA-X35
Sony VPL-HW50ES
post #6 of 8 Old 03-16-2013, 11:47 PM
leckian's Avatar
JVC DLA-X35
Sony VPL-HW50ES
I would buy the JVC but they are both excellent projectors and you can't go wrong with either one. The Sony reportedly has a slighly cleaner 3D picture, while the JVC is incrementally better in 2D mode.
leckian is offline
post #7 of 8 Old 03-17-2013, 12:31 PM - Thread Starter
HendersonD's Avatar
I have a completely light controlled room with dark walls and black ceiling which would, from what I read, make the JVC shine. My only reservation is noise, from what I read the JVC make a bit more noise than the Sony. The projector will be mounted directly above the seating, about 3-4' from my head. Any thoughts on noise?
post #8 of 8 Old 03-20-2013, 12:01 AM
jnabq's Avatar
Liked: 39
Might want to see if any users care to comment, or have posted an observation. http://www.avsforum.com/t/1442525/official-jvc-dla-rs46-dla-x35-owners-thread
jnabq is offline
Jvc Dla Rs46 Projector , Benq W1070 1080p 3d Projector , Jvc Dla X35 3d Hd Front Projector , Sony Vpl Hw50es 3d Projector
