Weirdness of my Panasonic AE 4000U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-24-2013, 01:26 AM - Thread Starter
socman's Avatar
I just purchased a "like-new" AE4000U. I really love this unit except for one issue. My lower left-hand corner of the projected image is angled upwards. It's not horribly bad, but certainly is noticeable. I had a Panny AE900U prior to mounting this unit, and it never had such an issue - in fact, it never had an issue! I just wanted to go from a 720P to 1980P. Honestly, there isn't that much difference. I must have had a great 720P unit!
Anyway, I was just wondering if anyone out there has had this experience. My installers told me that my wall was not perfectly flat and since my screen box hangs from the ceiling/wall, "it's off" and this causes my image to be sent upwards in the lower left corner....but, again, I never had this with my AE900U.
Any advice?
Roger
socman is offline
post #2 of 3 Old 03-24-2013, 03:17 AM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Are you using an extreme amount of lens shift in one direction or a good amount of both (H&V)?
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #3 of 3 Old 03-26-2013, 11:08 AM
ferbal's Avatar
Any advice?
Roger
Hi Roger
Looks like this?
Your new AE4000 has now a centered lens.
I think you have compensated this (if you installed it on the same spot) by rotating and tilting a little the PJ. To correct this you have to undo both. Level your PJ and turn it counter clock wise (looking at the screen). Use the lens shift mechanism and zoom to fill the screen.
ferbal is offline
