Presentations & memory projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-25-2013, 06:57 PM - Thread Starter
saas's Avatar
Hi
I have small question
If i save presentation in flash memory & insert in projector
Projector show animation in slide
Or
Projector show slide only
I want show presentation by projector remote control without pc
Answer important for me befor buy projector
saas is offline
post #2 of 2 Old 03-27-2013, 11:25 AM
Bohanna's Avatar
Liked: 24
I'm guessing it would depend on how you format the file and what format the projector can read so you will have to do the research. My PA70 can read divx files right from a stick and I believe from a hard drive. Not sure if it does an auto advance or can be set to a manual change for a PPS Presentation
Bohanna,.
Bohanna is offline
