Any projectors <$2000 with lens shift 78% or more? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-29-2013, 12:49 PM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
I'm looking for a projector with lens shift 78% of screen height or more, under $2000.
So far, the only options I've found are the Epson 8350 and 5010, which have 96% lens shift. Are there any other options?
Grayson73 is offline
post #2 of 5 Old 03-30-2013, 11:34 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
If basing it the way Epsons publish vertical shift, then the Epsons and Panasonics are the only ones I can think of that have a ton of lens shift.
Access HERE from this thread
coderguy is offline
post #3 of 5 Old 03-31-2013, 08:01 AM
Joesyah's Avatar
I see you've stated under $2000, but I know of one just slightly over 2k ($188 more with shipping included the last time I checked to be exact) that does 100% vertical lens shift. The Mitsubishi HC5 http://www.mitsubishielectric.com.au/assets/vis/HC5_brochure.pdf . As far as 2D goes it will be in a different league of PQ, than the other projectors you've mentioned. Should hang with the Sony vw95 in PQ, just slightly brighter because of the higher lamp wattage 230 vs Sony's 200 watts..
Joesyah is offline
post #4 of 5 Old 04-01-2013, 07:48 AM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
Which Panasonic? I was looking at the PT-AR100U, but it only has 65% vertical lens shift.
post #5 of 5 Old 04-05-2013, 08:20 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
The 8350 is a great value.
lespurgeon is offline
