LG PA70G owners - What size screen are you watching your projector with? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-06-2013, 08:57 PM - Thread Starter
kentuckyvid's Avatar
Got my room done and painted and now I am debating screen size. I have a really dark room and want to order a screen but the size and gain is throwing me for a loop. I want to go as big as possible so I am guessing at least 1.1 - 1.3 gain?
What size/gain are you watching your LG Pa70g on and thoughts?
kentuckyvid is offline
post #2 of 13 Old 04-06-2013, 09:42 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Screen size is based on your seating distance from screen. What is yours?
Jim McC is offline
post #3 of 13 Old 04-07-2013, 03:39 AM - Thread Starter
My room is 35ft long but I am just going to use half of it. I am limited by the 700 lumens.
post #4 of 13 Old 04-10-2013, 02:26 PM - Thread Starter
INPUT?
Anyone home?
post #5 of 13 Old 04-10-2013, 07:50 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
I didn't ask how long your room was. I asked what is your seating distance from screen?
I don't own that projector, but that doesn't matter.
Jim McC is offline
post #6 of 13 Old 04-11-2013, 08:03 AM - Thread Starter
New house and no furniture at this time. I can put my seating at any range. I also have 10ft ceilings. I can avoid cutting drywall if I put my screen on the narrow wall and not the long wall and that would limit my seating to about 13-14 ft.
post #7 of 13 Old 04-11-2013, 08:35 AM
thebigdaddye's Avatar
13-14 ft is around my seating distance and I have a 106" screen for my LG PA70G and I think it's perfect. biggrin.gif
thebigdaddye is offline
post #8 of 13 Old 04-11-2013, 07:25 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
For 13' to 14' I would go with a white screen between 110" and 120" diagonal, 1.0 gain.
Jim McC is offline
post #9 of 13 Old 04-12-2013, 02:55 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
Go with a 1.3-1.4 gain screen or if you can. Around 100 to 110in at max. This projector isn't bright enough for a 1.0 screen. I had similar experiences.
blee0120 is offline
post #10 of 13 Old 04-12-2013, 03:03 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
With any projector, I try to get at least 20ftL with a projector. I know its rated at 700 lumens, but I don't know how much in best mode. I assume between 550-600, but that's just a guess. You don't want the projector to seem too dim because of a too big screen. A dim picture with low contrast, will not look good.
blee0120 is offline
post #11 of 13 Old 04-12-2013, 04:30 PM
niceguy88's Avatar
I'm getting around 2Lm right now lol...
Seriously:D
EDIT: Fail for having to edit a two line reply
niceguy88 is offline
post #12 of 13 Old 04-12-2013, 08:42 PM - Thread Starter
I have it hooked up and blasting onto a gray wall at 120" and it looks great in low light. I am guessing buying a screen with a 1.3 gain will brighten things up though I am happy with the pic the way it is.
post #13 of 13 Old 04-17-2013, 10:12 PM
rservello's Avatar
1.0 gain 100" image. I use 120hz to brighten it up. Looks great to me.
rservello is offline
Lg Electronics Pa70g Micro Portable Led Projector
