Optoma HD 80 Bulb replacement or Color Wheel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-07-2013, 03:25 PM - Thread Starter
yoghurt's Avatar
Hello
My HD80's picture has been fine upto recently. Its okay for about 15 minutes then gradually goes blotchy (see pictures).
I read earier in this thread and it looked like the color wheel problem so I went in the SM and adjusted the setting but that does not seem to have helped
It has 800 hours in eco mode (so I guess 1600 actual hours). Is there anything else I can do to test this before purchasing a bulb or could it be a replacement Color wheel is needed?
Many thanks
Yoghurt
yoghurt is offline
post #2 of 6 Old 04-07-2013, 03:47 PM
Sheridan1952's Avatar
Sorry , it looks more like the image processor is failing. I don't believe the color wheel can cause what you're seeing, especially since you say it's fine when first turned on and the lamp DEFINITELY cannot do that.
Sheridan1952 is offline
post #3 of 6 Old 04-09-2013, 05:44 AM - Thread Starter
yoghurt's Avatar
Ok thank you, thats saved me some time
yoghurt is offline
post #4 of 6 Old 04-09-2013, 06:33 AM
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
One other possibility, Did you check the color wheel sensor. On a HD20 I would see something like this when it needed cleaning. Never saw much for dirt but a good dusting of the sensor with a small soft brush and clean air would solve it for months of watching.
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #5 of 6 Old 04-09-2013, 04:40 PM
tucsondave's Avatar
Looks like a heat problem. You could try using a fan to blow air into it to see if it lasts longer. It could be the internal fans are dirty.
Sometimes internal connectors can be affected by heat.
td
tucsondave is offline
post #6 of 6 Old 04-11-2013, 07:06 AM - Thread Starter
yoghurt's Avatar
Thanks guys-I have now opened it up and it did have a small amount of dust. I did not examine the color wheel in detail but will have a look at that
yoghurt is offline
