"Solved"projector not filling screen. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-08-2013, 06:23 PM - Thread Starter
elec4fun's Avatar
Hello just a little help.I have a Yamaha RX-V571 receiver,motorola DCH6200,and a Sony VPL-HS60 projector.My screen is 92*52
106 diagonally roughly.It is 192" or 16' form projector.Question is I have a 2" border around screen where no image is shown.
I have it set at 1080i through the cable box to get it to fill this much.While I know certain commercials are re sized smaller,do
you have any suggestion on how to get it to fill the full screen.Thanks
elec4fun is offline
post #2 of 5 Old 04-09-2013, 09:54 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Mostly likely you are too far from the screen - move the projector closer to fill the screen.
http://www.projectorcentral.com/Sony-VPL-HS60-projection-calculator-pro.htm
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 5 Old 04-09-2013, 04:12 PM
tucsondave's Avatar
If it's not filling the screen he needs to zoom out or move the projector farther away from the screen.
td
tucsondave is offline
post #4 of 5 Old 04-09-2013, 05:41 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
td
Yes of course you're correct. The point was I was trying to make was that according to the calculator at 16 feet he has slightly exceeded the throw range of this projector for a 106" diagonal screen. Either he's not using the zoom feature correctly or it's not functioning properly.
Mr.G is offline
post #5 of 5 Old 04-13-2013, 07:15 PM - Thread Starter
elec4fun's Avatar
Yep adjusted zoom on back side of focus ring and it did the trick.If I move the projector a little closer it would be perfect.Thanks.smile.gif
elec4fun is offline
