Projector/Screen Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-08-2013, 09:26 PM - Thread Starter
vanrags's Avatar
The Home Theatre is ready !. But the most critical components are missing. Wanted to get some advice on choosing a projector and screen for the room.
Here are the dimensions:
The distance between the power jack for the projector to screen: 158 inches
The size of the wall for the screen: 160 " wide X 54 " tall (it is taller, buit I have the center speaker mounted there)
I am looking at the following:
BenQ W1070
Optomo HD33
Screen: Jamestown 100 "
Please let me know....
Thanks !
VR
vanrags is offline
post #2 of 3 Old 04-09-2013, 01:50 PM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 95
As an owner of an Optoma, I find their products are unreliable. Mine was sent back twice in less than three years. I know that all company's have problems, but do some research on AVS and I think you'll find Optoma's are the worst. That said, my sister has an Optoma and never a problem. Regardless, I'd rec'd the BenQ.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #3 of 3 Old 04-09-2013, 03:35 PM
tucsondave's Avatar
If you can hold off for a few weeks you might want to check out the Optoma HD25-LV.
I own the HD33 but am looking at the 25 for the increased brightness and contrast.
Also longer lamp life since it uses a Philips lamp rather than Osram.
td
tucsondave is offline
