Mitsubishi HC7900DW owner's thread - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #1111 of 1291 Old 08-16-2014, 10:38 AM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 140
Originally Posted by greg1292 View Post
HC-7900 with about 800 hours on lamp less than a year old
worth 600-700?
Yes, in so far as I'd pay that amount for one, assuming great condition and no issues.
jjcook is online now
post #1112 of 1291 Old 08-16-2014, 03:01 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
no issues great condition
FJGDSAJGDSAKJ;GFLSKDJFL;SAKDJF;ALKDSGF;ASLKDJHGF;A LEWIJHGF;LSAKDNV;LSADKNGF;ASL/KDNGF;SALKDNG;ALSKDNGFLKSAGFLKSADNGFLKSADIMADUMBAS SL;KDSAFJKLD;;JFA;LDSHGFP[AWOEHGF;AWLIEHGF;AWLKEHGF;'AWLIENGFL'AWEKGF
greg1292 is offline
post #1113 of 1291 Old 08-16-2014, 03:19 PM
Charles R's Avatar
Liked: 536
worth 600-700?
Based on image size, screen, environment and the number of hours on the lamp you might be in the market for a new lamp. Even at zero hours the image is rather dim with "decent" size screens and up. Boosting the contrast +10 or more (doesn't crush whites) helps a little but not a lot you can do...
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #1114 of 1291 Old 08-18-2014, 07:54 AM
Deja Vu's Avatar
Quoted: 931 Post(s)
Liked: 936
Originally Posted by A L Wong View Post
If you are planning to watch 2D programs including sports in 3D using the 2D to 3D function, I'd say dun bother.
It is very dim and the colors are not stellar in 3D, in my case.
But to answer your question, Yes, getting the emitter and 3D IR glasses will get you 3D.
I certainly prefer "real" 3D to the Mits conversion; however, having evaluated many 2D to 3D converters (PowerDVD 11, 13 and 14, the 3D Bee, Samsung, Sony and Panasonic converters, the Epson 6010 and 6020 converters and presently owning the rather expensive Teranex 3D converter) I can only say that the 2D to 3D real time converter in the Mits, relatively speaking, is amazing and is in my opinion the number one bargain in 2D to 3D converters. If you're into 3D then check out this 2D to 3D converter. I would also recommend something like the Da-lite HP 2.4 gain cheap pull down screen for 3D viewing. This screen is retroreflective so no hot spotting; however, you need to place the projector just above or just below head height when seated to retain all of its gain -- table mounted will do. Earlier I posted some 2D and some 3D settings -- give them a try. You have to massage the Mits a little to get the best out of it for 3D; however, it's definitely worth the effort. I own four other 3D projectors (including the Sharp 30000) and the Mits, when set up for properly for 3D, is a standout.
Deja Vu is offline
post #1115 of 1291 Old 08-18-2014, 01:06 PM
paris401's Avatar
I don't think its that dim... in our batcave, black ceiling/merlot walls, dark carpeting, projecting onto a 0.95 115'' screen from about 15', the image is plenty bright...
Patrick Murphy likes this.
paris401 is offline
post #1116 of 1291 Old 08-18-2014, 02:02 PM
RPS13's Avatar
Liked: 31
I don't agree with that unless you're trying to go far larger on the image size than is recommended. I'm at about 300 hrs on my lamp, almost always on low, and with a 110" 1.2 gain screen it's borderline painfully bright on really bright scenes.
I'd say it's roughly twice (or a little more) the brightness of my LG PA70G on medium lamp and the settings boosted a bit to cartoonish to eek out a few more lumens.
Now if he's trying to light up a 150"+ screen, then I agree it's going to be marginal in low lamp mode. But that's asking too much out of the lumens available IMO anyway.
RPS13 is offline
post #1117 of 1291 Old 08-18-2014, 04:46 PM
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
Agreed. In my blacked out room on a 108" 1.2 gain white screen, the image is more than bright enough on the low lamp setting. If I jacked the contrast up to 10 to get some extra lumens it got bright to the point that it hurt my eyes on transitions from dark to bright scenes. My experience is 2D only, I have no interest in 3D so that may make a difference.
Edit: I forgot to mention that's with roughly 750hrs of low lamp time on the original bulb.
Thrillho is offline
post #1118 of 1291 Old 08-19-2014, 02:14 PM
DenisG's Avatar
Quoted: 65 Post(s)
Liked: 32
I use this projector as my living room TV. About 1750hours low lamp only. Room lets in lots of light during the day time, but I have a 110inch screen innovation BDM 1.4 screen, so day time viewing isn't a big deal.
DenisG is online now
post #1119 of 1291 Old 08-20-2014, 09:11 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Anyone replace this projector with something else? I like
the projector but looking to upgrade!!!!!!!! The question
is what would that be???
greg1292 is offline
post #1120 of 1291 Old 08-20-2014, 09:22 AM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 140
What price range, do you want to stick with DLP, 3D, and is gaming important?
post #1121 of 1291 Old 08-20-2014, 09:42 AM
paris401's Avatar
my 7900 is a replacement for my 10yr old infocus 7205 with less then 2000hrs on the orig bulb... imo, the 7900 is 10X the value/picture.. at 1/10 the price I paid for the 7205... i'm very impressed with the picture
my buddy has a 6month old jvc which cost him 6k (not sure of the model), and the 7900 imo def gives it a run for its money... at least in 2D, watching live sports...
paris401 is offline
post #1122 of 1291 Old 08-20-2014, 10:31 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
For sure going to need to spend some coin to get a noticeble upgrade.
greg1292 is offline
post #1123 of 1291 Old 08-20-2014, 10:33 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Looking used for sure 1300.00 to 2000.00 Marantz 11S2/Sony VPL-200 or 95ES. So many choices to go for.
greg1292 is offline
post #1124 of 1291 Old 08-28-2014, 06:35 PM
kopkiwi's Avatar
Quoted: 113 Post(s)
Liked: 72
What are people using for an anamorphic lens?
kopkiwi is offline
post #1125 of 1291 Old 09-04-2014, 05:51 PM
Liked: 0
Did anyone ever figure out a way to bypass the cable (in my case fios) picture being blurry on motion. My setup is an Cable box to a Yamaha Receiver connected via HDMI and Receiver to the projector connected via HDMI. Every other source (bluray/apple tv) works perfectly.
inimitable_g is offline
post #1126 of 1291 Old 09-05-2014, 03:02 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 197
I still have issues with my UVerse box. I believe the problem is the box can only output ether 1080i or 720p and the native content on some channels are 720p and some are 1080i. So if I leave the box at 1080i and the content is 720p the box converts it to 1080i then the projector converts it to 1080p causing a jerky picture in scans and vice versa if I set the box to 720p and the channel is 1080i native it causes the same problem. Everything works great with PS3, BR player and HTPC all set to output 1080p. I haven't found a solution other than changing the output of the box every time I change channels.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #1127 of 1291 Old 09-13-2014, 01:27 PM
gabthenab's Avatar
if anyone intersted what this projector looks like with Black Diamond screen ..
its now about 1600+ hour on lamp still give nice picture but im thinking now about th sony 40es
this video i just upload it
http://youtu.be/TasPv_QRz_g?list=UU-...57oHyS2trCz67A
gabthenab is offline
post #1128 of 1291 Old 09-13-2014, 06:25 PM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Very nice! Seems to handle ambient light well.
I keep my 8000 in a light controlled environment on a 92" screen and the brightness is great at low lamp. However, I wouldn't go much bigger than 96" with this projector.
Cory
Audio: Ascend Acoutics, Sennheiser HD 598, Denon AVR-S710W
Video: JVC DLA-RS400, LG OLED B6, 92" Dark Energy Abyss screen, HTPC/MadVR/Darblet, Samsung UBD-K8500 UHD Player, HDFury Integral
CoryW is offline
post #1129 of 1291 Old 09-24-2014, 04:17 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Ok.....finally getting our basement done to where this projector can go up.
I already have these glasses http://catalogs.infocommiq.com/avcat...dtv&product=jp
Says on description that will be compatible with an emitter...but I'm not sure?
And was thinking this emitter?
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Will that do the trick?
Mckinley1 is offline
post #1130 of 1291 Old 09-25-2014, 12:32 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Anyone throw me a bone here and see if this should work? Thanks
post #1131 of 1291 Old 09-25-2014, 02:27 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 197
To the best of my knowledge this will not work, in theory it should but some have tried it with no success. I used a OEM IR Mitts emitter from my Mitts RPTV with the Samsung glasses and it worked but had ghosting issues. I also tried Expands Blue tooth emitter and it also worked but the ghosting was even worse. The OEM Mitts emitter (expensive and in short supply) designed for this projector with PS3 IR glasses works well from reports or the best solution is the RF glasses using the Optoma emitter discussed many times in this thread (what I am using now) .
post #1132 of 1291 Old 09-25-2014, 06:50 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Will it not work because of the glasses or the emitter?
Will the glasses work with a different emitter?
Guess im confused as to what makes it 3d if you have to search high and low to find other gear to make it actually work?
post #1133 of 1291 Old 09-25-2014, 07:52 PM
A L Wong's Avatar
My FRC option has suddenly greyed out.
This first happened with HDMI 1 input, and despite re seating all the cables and restarting, making sure signals are 1080p, it remained greyes out.
I switched to HDMI 2 and the option was live , until last night. It greyed out again and despite restarting, etc...
Switching back to HDM 1 did not help.
Has anyone else experienced this and what is the solution?
Thank you.
A L Wong is offline
post #1134 of 1291 Old 09-25-2014, 07:58 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Ok is this essentially what I need then? No splicing of cables or anything...this will work?
post #1135 of 1291 Old 09-25-2014, 08:06 PM
A L Wong's Avatar
Ii am pretty sure it will not work.
http://www.amazon.com/purchased-Mits...sin=B005CWID0A
A L Wong is offline
post #1136 of 1291 Old 09-25-2014, 08:14 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Ok thanks.....what about the post I had above yours? Will that work?
Or what is the best economical, easiest, non splicing way to make this thing actually do 3d?
post #1137 of 1291 Old 09-25-2014, 09:13 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
Or can someone just tell me if I have a ps3 and just want to watch movies in 3d.....what I would need?
Thanks for any help....just no idea what I'm doing.
post #1138 of 1291 Old 09-25-2014, 10:43 PM
Mckinley1's Avatar
Quoted: 14 Post(s)
post #1139 of 1291 Old 09-26-2014, 03:20 AM
A L Wong's Avatar
The emitter needs to have a 5 pin DIN connector to plug into the projector.
Your link shows the emitter with a 3 pin connector. It will not work as supplied but can be made to work if u splice it with the original 5 pin connector that comes with the projector.
If you do not want to splice, your only option is this.
http://www.amazon.com/EY-3D-EMT2H-Mi...ubishi+emitter
It took me all of ten minutes to do the splicing and I am no handyman for sure.
A L Wong is offline
post #1140 of 1291 Old 09-26-2014, 06:22 AM
Mckinley1's Avatar
Quoted: 14 Post(s)
Hmmm ok....where is the splicing information? I've been looking and can't find it.
Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc4000 300 Inch 1080p Front Projector
