BenQ W1070 strange dots? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-17-2013, 09:33 AM - Thread Starter
just4u32's Avatar
Hey,
I've been experiencing something quite wierd which I've never seen on projectors before, 3 dots - 2 in the middle of the screen, one next to the other, and one close to the bottom left corner.
Say this is my screen, the black circles are dots:
The dots seem much brighter from the rest of the screen, but my camera won't catch it.. I also see it in dark scenes, and even when no source is connected (the no signal screen).
Any ideas?
just4u32 is offline
post #2 of 17 Old 04-17-2013, 04:09 PM
Adamd's Avatar
Quoted: 741 Post(s)
Liked: 428
Could be dust stuck in the inside. Can you return it?
Adamd is offline
post #3 of 17 Old 04-17-2013, 04:53 PM
Morkeleb's Avatar
As Adam said check the lens. With the projector off I'm betting you have specs on your lens. I have one on mine from when I remounted my projector. Some how a spec got inside the lens. It is only visible when it's searching signal when the screen is black. I don't see it when a movie is on. Maybe your specs are larger than mine.
Disclaimer:
The words above are based on loose facts mixed with my opinion, the latter of which is subject to change.
Gamertag Morkaleb
PSN Archathema
Morkeleb is offline
post #4 of 17 Old 04-17-2013, 05:09 PM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
Stuck mirrors?
Verge2 is online now
post #5 of 17 Old 04-17-2013, 05:53 PM
rayweil's Avatar
How big are the dots? Are they constantly in the same area?
rayweil is offline
post #6 of 17 Old 04-17-2013, 06:16 PM
jnabq's Avatar
Liked: 39
Sounds funny, but one poster had something on the screen, but moving the zoom might help you determine if it's dust?
jnabq is offline
post #7 of 17 Old 04-17-2013, 08:41 PM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1391
When I defocus (or re-focus to the lens itself) I also see some kind of specks on my image. I was going to try and wipe the lens clean with some kind of cleaner. Can anyone recommend one?
RLBURNSIDE is offline
post #8 of 17 Old 04-17-2013, 08:49 PM
zapper's Avatar
Quoted: 53 Post(s)
Would not use a cleaner at all, just plain water on a clean wash cloth that has no lint, perhaps some one else will chime in with a better answer, say look at the manual and see what they say to use.
Ralph
zapper is offline
post #9 of 17 Old 04-18-2013, 10:53 AM
RLBURNSIDE's Avatar
Liked: 1391
I tried water, it didn't work. I can clearly feel the bumps on the surface though, which is good news because all it means is that it's dust caked on due to the heat. Meaning I should be able to get it off. (though it's only really apparent when focused on it, I'm sure it does alter the projected image a little bit.
post #10 of 17 Old 04-18-2013, 01:55 PM
jnabq's Avatar
Liked: 39
http://www.manualslib.com/manual/422315/Benq-W1070.html?page=47 BTW, it does specifically instruct you to NOT use insecticide. wut?? smile.gif
jnabq is offline
post #11 of 17 Old 04-18-2013, 02:15 PM
zapper's Avatar
Quoted: 53 Post(s)
Did you get a chance to look at the manual,page 47 it states on how to clean the lens.
Ralph
zapper is offline
post #12 of 17 Old 04-19-2013, 12:03 PM
RLBURNSIDE's Avatar
Liked: 1391
It says to use a professional lens cleaning brush and cleaning agent, but I have no idea where to buy that, they didn't appear to have that at Home Depot.
I tried some wipes and it didn't get the caked-in specks off. There's a big-ish one right in the middle of my screen, I'm sure it's costing me some clarity but it's being real stubborn. Maybe it's melted into the glass now, eek. It seems very much part of the lens now.
post #13 of 17 Old 04-19-2013, 01:09 PM
zapper's Avatar
Quoted: 53 Post(s)
Try a camera shop in your neighborhood and tell them what you you are looking for, do not have to get the best just something that will do the job for you.
Ralph
zapper is offline
post #14 of 17 Old 04-21-2013, 04:56 AM
McStyvie's Avatar
Liked: 78
a lens cleaning cloth and or kit from your photo shop will do the trick.
McStyvie is offline
post #15 of 17 Old 11-15-2013, 12:54 PM
Korihor's Avatar
Did you ever fix your problem? I have one of these dots in the upper right hand corner of my screen, (only visible when image is very dark).
"I've come to believe that we are living in a great VOID!"
Korihor is offline
post #16 of 17 Old 11-15-2013, 05:35 PM
theLorax's Avatar
I apparently have one of these too but tried cleaning the lense and still there. Is it possible this could be on the inside.? Projector is only a few months old. frown.gif
theLorax is offline
post #17 of 17 Old 11-28-2013, 06:08 AM
Denis Ricardo's Avatar
Hello guys,
I have the same problem from colleagues.
I cleaned the lens and even then the bubbles are still visible in darker images :-(
I got open the projector and clean it with compressed air but still did not work ...
I believe that the problem is inside the lens ...
Does anyone know any tutorial?
Thank you.
Denis Ricardo is offline
Benq W1070 1080p 3d Projector
