LG PA75U -Anybody else own one of LG's Abandoned Children? - Page 14 - AVS Forum
 7Likes
post #391 of 457 Old 03-30-2014, 06:45 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
The Bluetooth remote doesn't need to be out of range, just set down somewhere so it holds still (not on a lap or rockingchair). If you're really concerned you can just pop the battery latch so it springs loose, this is what I do when traveling with it so a button getting mashed in transport doesn't waste the batteries. I've been using the BT remote for 4months so far with the original offbrand batteries. I use it more than many between internet, settings tweaking and teasing cats. I do hope I can get the regular remote working because it's nice having keystone buttons right there, occasionally.
Simple <$250 dedicated black-fabric theater room, build in a day, takedown in an hour.
Easy $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Ftoast is online now
post #392 of 457 Old 03-31-2014, 08:06 PM
007india's Avatar
That's a better idea. I thought that devide will search for bluetooth in the event if it can't latch.
I have put a plastic film in between the battery edge and electrode in remote. Whenever I wish to use the remote, I wll just remove the thin film and put it back once I'm done. Since mine is a permanent setup, I wish key stone adjustment might not required smile.gif
Did you ever tried to screen your smartfone to the projector. My room mate has a Samsung Tab3 8, which has Android 4..2.2 with Widi. The projector and Tab did seem to detect each other through Wifi, but not sure why I couldn't share the screen of my tab to projector. The steps given in manual is inadequate.
007india is offline
post #393 of 457 Old 04-01-2014, 02:56 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
I have wirelessly played videos from a Samsung phone through the LG, but full-on screen mirroring from a phone usually requires either a specific hdmi wireless adapter or only works with a certain small set of phones. There might be a phone version of the magic mirror app too, which should work alright but is probably $10. The Wireless screensharing (where it shows a live-stream of your entire monitor) of the LG without any extra loaded apps is limited to x86 computers running compatible software, and I haven't gotten that to work.
It does well with recognizing any available wireless shared videos and networking things like that, it just doesn't seem to like mirroring so you can wirelessly play games or use it as a general wireless monitor without the magicmirror app. I hear wireless without a wirelessHDMI adapter is laggy anyway and not useful for gaming or much else besides slideshows and movies..which it already does wirelessly.
So yeah, wireless video/picture streaming works, but full-featured screen mirroring seems flopped.
If you have WiFi available DLNA works awesomely, but without WiFi (using WiDi) I'll try again but don't remember getting it working either.
post #394 of 457 Old 04-01-2014, 11:58 PM
007india's Avatar
Yes, files in my tab(Samsung Tab3 311) can be played from projector (just like a pendrive) through Wifi DLNA. But screen mirroring doesn't work. My tab has a in built screen mirroring function and a built in Widi too (all androids of ver 4.2 and above has this feature). But still the handshake doesn't happen.
007india is offline
post #395 of 457 Old 04-02-2014, 10:19 AM
Jonathan Hersey's Avatar
So How long will this Thing last with FULL brightness and energy saving at MINIMUM? 30000 Hours cant be right?!
Jonathan Hersey is offline
post #396 of 457 Old 04-02-2014, 11:45 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
I've seen some LED models listed as low as 15,000 and high as 50,000 before lowering to 80% brightness. We can certainly all hope for the best..which means I'll have an answer in 25years if LG did alright or much sooner if they didn't, lol. If I had to guess, I'd think they'd still be good for 10,000+ even in the worst cases.
Apparently they're cheaper to re-bulb than a JVC if the LEDs go before something else because someone was quoting Lumagen(I always screw up the name) light-engine MSRPs somewhere, and I remember them running around $250 for a single-order/regular consumer. Seemed cool that they'd sell to anyone, but I can't confirm if it's really the truth.
post #397 of 457 Old 04-02-2014, 12:23 PM
Can LED RGB Bulbs in projectors like the LG models be "Replaced" or "Hacked"?
- Do they sell the bulbs or kits? can this be on http://www.instructables.com?
post #398 of 457 Old 04-02-2014, 03:03 PM
Bohanna's Avatar
Liked: 24
Good luck with that! LED's either work or they don't. Its that simple. Currently The ones that are in projectors can't produce the high light output of lamp based Projectors. Take it from someone who has spent THOUSANDS of dollars and HUNDREDS of hours trying to retro fit projectors with LED's or less expensive metal halide lamps. You are wasting your time. Now that the price has come down you would have to be an idiot to even try!! You can make up your own single TFT screen LCD in a box with a lens and a Home depot lamp that will look OK but it will be nowhere the quality of a commercially made Projector - Bohanna
Bohanna is offline
post #399 of 457 Old 04-02-2014, 03:14 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
I'm pretty sure you can get kits (of the bulbs/light sources) from both lumagen and little LED kits from TI. You can also get limited DLP kits from TI and some manufacturers sell DLP/LCoS panels+boards for decently affordable prices. It really makes me wish I was a smarter person sometimes, lol.
post #400 of 457 Old 04-02-2014, 07:05 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
Okay, it's kinda funny and ironic having the longevity brought up..now that my heart-rate has lowered back to normal. My PA75u just took an overly dramatic fall while I was lifting it over some furniture, on a tripod how you aren't supposed to. I must've failed the lock and the PJ threw itself several feet down, broke some China and bounced up onto a chair! I picked it up and it cracked back together in my grip. I gave it a gentle shake, heard the light sound of broken glass inside and commenced cursing.
Figuring there's little to lose from a quick test it powered right up and looks perfectly normal. I gave it another shake and didn't hear anything, so now I'm wondering if it just had a little bit of China in the fan-vent that shook out. I'll be back to gripe if it turns out broken, but it seems fine so far.
Either way, on the bright side, the bounce didn't have it land on my laptop.
post #401 of 457 Old 04-03-2014, 08:08 PM
007india's Avatar
Don't worry, its your hard earned money, so it survived.
@Ftoast: May be you might have just fixed the lens alignment issue smile.gif pls give a step by step procedure on how the fall happened from tripod so that others can follow to get their lens issue fixed smile.gif may be LG might be snooping on this forum and may put your steps in to their manual 'OMG'
007india is offline
post #402 of 457 Old 04-03-2014, 10:50 PM
DLPProjectorfan's Avatar
Liked: 34
Yeah, those projectors can become top heavy on a tripod.
So you were lifting it up over a piece of furniture ? was it a couch because you said it bounced back up onto a chair ?
These LED projectors are pretty much solid state, hardly any moving parts other than the fans, that's another reason why I love them biggrin.gif no color wheel to wear out or shatter.
You said all in the same fall and movement you gripped the projector ? and the case snapped back together ? in your words cracked back together.
So the force of the fall caused the case of the projector to come apart ?
These LED projectors can take a little trauma and still work, but still pretty much wont survive in a intentional smash'em up on the concrete floor and see if it survives force.
The old UHP bulb and color wheel projector ? even if you accidentally bumped your head against it could, might, maybe cause damage to the projector.
When you shook it it did sound like broken glass ? or a screw that was broken lose inside the case ?
I can't think of anything glass other than the lens, but those are suppose to be made out of plastic, or the lens in front of the LEDs.
That is ? if the LGPA75U has a lens in front of the LEDS.
The things I would worry about are the main lens, the light path and mirrors, and fans.
Everything else could ? maybe take some what of a shock and survive.
DLPProjectorfan is offline
post #403 of 457 Old 04-04-2014, 02:28 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
It was being lifted over a pair of rockingchairs separated by a short table with a large China bowl. It landed on the bowl hard enough to bounce up and over a chair's wooden arm and end up seated in the chair. The back halves must've misaligned slightly between the corner screws (nothing was noticeably apart and nothing feels loose), then it popped back in place as I picked it up from its seat. I guess one of the plastic clips that hold it together popped out of place in the fall and then back in from the slight squeeze. The rattle sounded like very small slivers of glass (or maybe ceramic/china) but it either settled somewhere or fell out because it doesn't do it now. The fans are still quiet too, so nothing got stuck or messed up there.
I've read a review of one of the cheaper benq's taking a fall from a shelf and still playing as long as a weight(book) was placed on top. I've watched a few hours of video and everything is as if nothing happened.
As a side, I finally have a solid 105" screen in the family room that flips up to lay along the ceiling (so the TV is unblocked) and despite being surrounded by windows with terrible curtains (next project..better curtains), I can't get 3D to lose sinc for more than a second. Even turning away from the screen doesn't throw it off, I don't know if it's the PJ or if I got really lucky with these $12 DLPlink G15's but I'm trying to think of excuses to use 3D more often.
post #404 of 457 Old 04-07-2014, 12:58 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
Brought the LG to a friend's and whatever is inside -broken- IS still inside rattling around on occasion. I'm really not looking forward to taking it apart again.
post #405 of 457 Old 04-12-2014, 07:45 AM
teddy0890's Avatar
I wonder it would be better to use this projector with a silver screen or a white screen. I'm not quite happy with the white wall that I'm using right now. Have anybody use the silver screen with it? I don't know if the noise and hot spot problem in silver screen would be an issue for a low lumens projector like this one.
teddy0890 is offline
post #406 of 457 Old 04-25-2014, 11:47 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
It's a glorious sunny morning. The PA75u is still set up behind the familyroom seats from last-night's viewing and the 110" flat-white screen takes 5seconds to unhinge down in front of the LCD TV. The room is white; white walls white ceiling and off-white carpet. It's surrounded by windows without curtains and china-hutches with mirrored backs. This is a bad room at a bad time with a cheap LED projector. LET'S TAKE SOME PICTURES
The LG is setup for daytime viewing right now, with brightness turned up so blacks aren't terribly crushed by the sun and colors are turned up a little past clipping so they aren't as washed-out. There's one more weapon in its arsenal. "Dynamic Contrast" is a setting (off/low/med/high) that takes the image and tries to stretch the scene's contrast until the brightest part is near-white and the darkest part is wherever you have "brightness" control set. It, therefore can't do much to high-contrast scenes nor very bright scenes. It also tends to wipe out some small details and I recommend shutting it off during any dark-time viewing, BUT it really helps low-APL scenes cut through a bit of light.
The top row of pictures shows a midAPL live-action scene, a highAPL animated scene, and a very lowAPL live-action scene with plenty of black space.
The lower six shots show how much difference lowering the backlight/LED-brightness makes, going (left to right) bright, medium, dim.
That's roughly 400lumens trying to fill a 56"X90" space with about 11.5ftL.
eric3316 likes this.
post #407 of 457 Old 04-25-2014, 01:32 PM
AV_Integrated's Avatar
Quoted: 374 Post(s)
Liked: 393
That's a great set of shots and represents what I would consider an unusable on screen image. About a 6:1 contrast ratio. You can tell what's going on, but you aren't going to be enjoying the viewing experience at all.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #408 of 457 Old 04-25-2014, 02:32 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
Thanks, I consider myself "blessed" with a situation that can show a fair worst-case-scenario, lol.
Something neat to consider then, even a monster PJ putting out 4000lm would only be achieving roughly 60:1 contrast in the same place, and the much easier alternative to start with is curtains. Curtains for daytime and some simple, appropriately dim, directional lamps for night-time are easy steps that anyone can perform without spending much money at all. With a higher contrast projector, dark/flat paint is a good consideration, but I wouldn't bother with this particular PJ or much anything else that's similarly inexpensive.
-That dopey screen was about $25(including "mounting" parts), 15minutes of rolling paint, and it weighs about 2-3pounds and can be hung from any ceiling without issue. It sits flush with the ceiling out of the way when not in use and can lower in front of the TV when needed.
-Decent dark curtains are easily had for $20-30 a pair, and lamps/spots are a paltry $30 investment.
-Find a seat or a low shelf to put behind your seats if you don't want to ceiling-mount, and leveling can be a one-time investment of a few minutes.
-Perfectly watchable 1080p PJs are available in the $700-900range and 720p is down to $400.
Part of me doesn't understand why more people aren't putting projectors in their homes, but another part loves that little feeling of being "special". Ha.
post #409 of 457 Old 04-26-2014, 06:21 AM
Bohanna's Avatar
Liked: 24
Its a Freaking Portable Projector with a LED light source. For what it does its great for the price. Try putting it side by side with a high Lumen projector and you will still get crappy images in a well lit room. Its really kinda dishonest to use the worst possible set up and complain that its a "Cheap LED projector" If you have kids its probably one of the best all around projectors on the market for the price, Especially if they are growing up and will be using it for video games net surfing and other things that kids do. Time had pretty much proven that kids and lamp based projectors can be a VERY expensive proposition. I wonder how many parents have had to turn around, drive back and check if junior left the projector on or has heard "Mommy or daddy The projector won't come on" just to find out the new lamp has exploded because Junior wants to turn it on and off like a regular TV. Get real! - Bohanna
Bohanna is offline
post #410 of 457 Old 04-26-2014, 08:13 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
I hope you realize that I absolutely love this PJ (even despite my hatred for LG) and was showing a clearly defined worst-case scenario because I felt as if my beloved, cheap, LG was holding it's own fairly well given the circumstances. I wasn't complaining at all, and certainly didn't mean to sound like I was. For the record, I've been significantly LESS impressed trying a 3000lm LCD in that same space as well as a 3500(dirty lie)DLP.
I posted a set of similar pictures showing this LG (in brightest backlight) side-by-side the 2500lm-claiming hd131xe(eco mode) going through the whole spread of "Brilliantcolor" brightness-enhancing options. I thought the little LG held its own so well in ALL regards compared to the Optoma that I'll be returning the Optoma to the store. Every major thing important to me that the Optoma did well, the LG matched or bettered. For a cheaper price.
I figured newbies might see these and go "That's the worst? Pfft. That's not as bad as some have made it sound."
Or at the worst realize "Huh, that's not gonna be me. I'm putting curtains on my next shopping list."
There's no dishonesty in posting accurate pictures of a clearly defined situation. If somebody new to projection wanted to know what to expect from a PJ in a bright room, the most thorough answer is showing them. If they don't like how it looks and know they won't be able to darken their room, they are justified in being scared away.
post #411 of 457 Old 04-26-2014, 10:23 AM
Bohanna's Avatar
Liked: 24
The pictures you posted were horrible and would scare any Noobs into staying away from projectors period! How you could take the worst case scenario and think anyone would believe you Absolutely Love the PA75 boggles the mind. Its pretty clear that your minds eye and a normal minds eye are not on the same page or for that matter even in the same book! - Bohanna
Bohanna is offline
post #412 of 457 Old 04-26-2014, 06:19 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
These pictures were taken with the hd131xe(top) and pa75u(bottom) simultaneously showing the same paused scene.  The pa75u is at its brightest backlight setting while the 131xe is in ECO mode using a new bulb and about 1ft. farther back.
The pa75u(bottom) is the same in all 4 shots (brilliantcolor OFF) and was set as close as it would get to match the Optoma(top).
Left to right; Brilliantcolor is low, medium, high, high. The last/fourth (high) also has CMS color gain controls cranked and deep colors are clipped because of it.
I consider all of these easily watchable (photography skills notwithstanding), but the first and last ones are the most pleasant and least "washed out".
 Sadly the color-gain cranking trick doesn't work well when you're dealing with high-color content.
The lower image of each pair is the same across all four shots, and has brilliantcolor OFF.
It starts out good and balanced, then it gets weird with the unbalance from BC, THEN it gets downright ugly with the combination of BC's unbalance along with clipped color problems.
The first image is fine, but the second and third are getting distractingly bad with glowing whites. That last image is even worse in person, if you can believe that..the camera just refused to capture the full "badness" of it, I suspect out of pity.
post #413 of 457 Old 04-27-2014, 08:35 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
Here's what those three different mid/high/low-APL shots look like at four common room-light situations using the PA75u.
Top to bottom:
-Direct sunlight pouring in mostly though the large bay window at my back.
-Indirect sunlight with the sun blurring through some cloud cover.
-Dawn light, plus indoor adjacent lighting around 400watts.
-Dawn light, all indoor lights off.
There's enough light in the room to read small print in the top two picture-sets and more than enough to pass some snacks around or walk without stumbling in all four sets. The dim, early morning light (lowest row) provided a wonderful compromise of usable light for navigating the somewhat messy familyroom without noticeably hurting the on-screen image, and a simple pair of dimming table-lamps should yield similar results.
post #414 of 457 Old 05-05-2014, 06:26 PM
Kaise7en's Avatar
Hello all! I am glad to see I'm not the only one going the LED projector route. I have been an owner of a LG HX350T projector for several years and it has worked wonderfully. I also picked up a qumi q5 but it's more my outdoor projector now, not too impressed with it. Buuut..... I just recently picked up the pa75u at Bestbuy for 599.00. They had it labeled wrong and I was holding them to it. So I have this set up in my basement in a dedicated theater space, ceiling mounted on a 106" low gain high contrast grey screen. It actually looks amazing! But thanks to my job I am now taking the plunge and really making an upgrade. I ordered a 106" Black Diamond screen!!! The guys at work have their preferences to sell to customers, the Sony 55es or the 600 if someone is ready for 4K, or Epson of course or Runco if you really want high end. Don't get me wrong, I'm not comparing my 600.00 projector to a 4000.00 Sony or anything. I use my projector every day. Every....Day. So for me the LED just makes sense. I am amazed how great it looks and I haven't really adjusted much and the 3d was surprising good. And not an ounce of focus problems. I'll take photos of the new screen once it arrives at the store. If you haven't guessed already I work at a high end home theater shop. I get to geek out on the new gear and get paid for it. Pretty dang cool. Thanks.
Kaise7en is offline
post #415 of 457 Old 05-07-2014, 08:04 AM
Kaise7en's Avatar
Just wanted to get it out there, best buy has this on clearance for 599.00.
Kaise7en is offline
post #416 of 457 Old 05-15-2014, 03:14 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
The w1070 finally arrived, so I've taken a few side by side pictures of it next to the PA75u. Besides the brightness and contrast difference being a little less dramatic than I'd hoped, I also noticed a strange advantage of the LG's pixel structure..When dealing with resolution lower than 1080, and/or when using 1080 coupled with digital keystone correction (which should be avoided if possible) the LG appears to have smoother yet sharper edges and less image noise despite having noise-reduction set OFF. The w1070 is still the sharper projector for 1080 material (as long as digital keystone adjustment isn't used), but for everything that uses re-mapping the LG seems to have a visible advantage.
The W1070(top) is in "eco" set for cinema mode with contrast boosted slightly and "BrilliantColor" turned OFF. The LG(bottom) is on brightest backlight setting with "DynamicContrast" turned to MEDIUM
Despite output hypothetically being around 900lm for the w1070 and around 400lm for the LG at these settings, the perceived brightness was very similar. A bit disappointing.
Next, the W1070(right side) is set for boosted colors/contrast/gamma/brightness at full lamp brightness and "BrilliantColor" is ON. The LG is still set for brightest backlight and "DynamicContrast" at MEDIUM. This is during the day, using a smaller image size in the daylight.
The DynamicContrast of the LG keeps the dark APL scenes looking similar, but the brightness advantage of the w1070 shows through during the brighter scenes. In person the W1070 looked a little cold at these settings but plenty watchable, and there's always the option to sacrifice some of the brightness to warm the picture.
Still, the knowledge that the w1070 will lose nearly half of its brightness after a year of my usage habits coupled with the lack of visible contrast improvement means the W1070 will be getting returned and my search will have to continue.
post #417 of 457 Old 05-19-2014, 09:10 AM
avboy1's Avatar
I just got a used PA75U recently.  But to my dismay that system was password locked.  I search every where on the net and couldn't find a solution to reset it.  Any one can help with that? How about open up the case and looking for CMOS reset?  I can reset desktop motherboard, most electronic gadget has reset hole some where at the bottom.  But not this one.
avboy1 is offline
post #418 of 457 Old 05-19-2014, 09:11 AM
avboy1's Avatar
avboy1 is offline
post #419 of 457 Old 05-20-2014, 05:27 PM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
According to LG, when prompted for the password, type 0000 then go into options/set-password and turn it OFF. They say 0000 will be a default that will let you through to disable password protection..I've received misinformation from LG support before, so I can NOT say if this will work for sure.
Okay, tried it myself. If someone has changed the default password, using 0000 will NOT work. It's worth a try if you haven't already.
If it doesn't work, have the unit within reach and call 1800 243-0000 to see if LG support can help you more specifically.
post #420 of 457 Old 05-21-2014, 02:14 AM
Ftoast's Avatar
Quoted: 435 Post(s)
Liked: 223
I ran out of extension-cord before I could get a larger image, but this being 16-17ft wide helped the camera pick up the picture a little better anyway. The siding is a flat, dirty off-white and phone-cameras aren't exactly renown for their ability to capture low-light well, but the little LG is still bright enough to get some decent pictures at a size that's too big for many indoor areas.
If only the mosquitoes around here weren't immune to TikiTorches I'd have it made.
Okay, found another cord. This was measured at 25ft. wide. There was a small fire about 30ft to the left, but it didn't seem to hit the picture hard enough to do any damage.
Lg Pa75u Dlp Home Theater Projector
