Runco CL-510 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2013, 08:36 AM - Thread Starter
gwhicker80's Avatar
I am looking at possibly purchasing a projector. I found a Runco CL-510 on craigslist for $400. I know it is an old projector and was curious whether it would still be better than a new projector today at the same price point. I will be watching 100% movies, dvd and blu ray, no 3d. It will be set up in a basement with not much ambient light. All opinions are appreciate.
gwhicker80 is offline
post #2 of 4 Old 04-21-2013, 03:15 PM
pulpblogger's Avatar
I would't pay more than $50 for it, Runco or not. It is 16:9 but only has 576 lines of resolution -- not even HD and replacing the lamp could easily cost you $3-400. A used optoma hd20 would blow away the cl-510 and if you are lucky, you could find one at the same price point.
pulpblogger is offline
post #3 of 4 Old 04-21-2013, 03:48 PM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
+1
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 4 Old 04-22-2013, 03:39 AM - Thread Starter
gwhicker80's Avatar
Thanks for the info
