Sanyo PLV-Z700 Help Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-09-2013, 08:26 AM - Thread Starter
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
Does anybody know where I can buy the filter for this projector at a reasonable price? Please PM me if you do.
macfan is offline
post #2 of 2 Old 05-09-2013, 11:21 AM
Bohanna's Avatar
Liked: 24
you could use an outside auto air filter mounted on top of the air intake. ,,,, much better than the stock ones. Just make sure you take the factory one out if it is clogged or you will kill the lamp fast
Bohanna
Bohanna is offline
