HD70 startup issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-11-2013, 06:05 AM - Thread Starter
kick ass sub's Avatar
I've been a satisfied owner of the Optoma HD70 for six years now and recently changed the bulb.
A few weeks later the fans would start working when I turn on my projector put the lamp refuses to turn on and after a few seconds the projector shuts down automatically and the lamp error LED starts blinking.
When I take out the lamp and put it back in the projector starts working again. But a few weeks or days later the problem would occur again. I doubt there's a problem with the lamp itself, as it always works again if I took it out the projector.
Does anyone has an idea of what the cause may be for the lamp not lighting up?
Display: Optoma HD70
Player: PS4 Pro
Receiver: Pioneer 1015
Fronts / surrounds: SVS SBS-01
Centre: SVS SCS-01
Sub: SVS PC13 Ultra
kick ass sub is offline
post #2 of 6 Old 05-11-2013, 08:33 PM
behengold's Avatar
I've had a similar problem with my panasonic. Someone suggested it might be the ballast. I unseat and reseat the bulb and it turns on. Happens about every 4-5 times I turn it on. I just live with it till I'm ready to upgrade.
No one praised a car more then the man who bought an Edsel.
behengold is offline
post #3 of 6 Old 05-11-2013, 11:40 PM - Thread Starter
I don't plan to upgrade for a few years. Is it expensive to change such a ballast?
Player: PS4 Pro
Centre: SVS SCS-01
Sub: SVS PC13 Ultra
post #4 of 6 Old 05-12-2013, 06:10 AM
tucsondave's Avatar
Is there any way you can get to the lamp connector to clean the contacts?
That would be my first thing to try.
td
tucsondave is offline
post #5 of 6 Old 05-12-2013, 06:21 AM - Thread Starter
Well, I guess just taking the lamp out and cleaning the input connector for the lamp. I plan to call my HT dealer tomorrow.
Player: PS4 Pro
Centre: SVS SCS-01
Sub: SVS PC13 Ultra
post #6 of 6 Old 05-12-2013, 07:57 AM
behengold's Avatar
I think everything's expensive with electronic repairs.I'm not sure what a ballast would cost or how difficult it is to put in.I replaced the fan thinking that might be the problem.I've had friends send projectors back for repair and It takes forever to get them back. if I can't fix it myself I replace it. On recent big ticket purchases I bought the extended warranties so it becomes the dealers problem, not mine.Good luck.
