EPSON EMP-TW100 line problem ..please help!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-13-2002, 03:17 PM - Thread Starter
coupe333's Avatar
I have the epson tw-100 a few days and i noticed some vertical lines that are repeated every 1,5 cm . is this normal or something is going wrong?..
Thanks in advance
(sorry about my English)
coupe333 is offline
post #2 of 16 Old 06-14-2002, 02:34 AM
inli's Avatar
This has beed reported many times and can be seen on many TW100 and other LCDs. Please read the other TW100-Threads.
Ingo
inli is offline
post #3 of 16 Old 06-14-2002, 05:48 AM - Thread Starter
coupe333's Avatar
Thanks inli, but i think theare is a differnce between "many" and "all"....
If theare is just one that dont have this lines it means that the athers are deffective.....
coupe333 is offline
post #4 of 16 Old 06-14-2002, 12:41 PM - Thread Starter
coupe333's Avatar
Please give me an answer...
coupe333 is offline
post #5 of 16 Old 06-14-2002, 10:32 PM
mltl's Avatar
If you have a test dvd,make it show the pure color or grey screen and find out what makes you feel that lines.Or you should post the screen shot for it.I have tw100 too, and I don't think which you say is happening on my tw100.
BTW,I found that lines on screen with my Mitsubishi sa51u,and when I take it return to the sales,he said,'I don't think I can see any lines on it'.
mltl is offline
post #6 of 16 Old 06-15-2002, 04:33 AM - Thread Starter
coupe333's Avatar
Heare ara some pics from the line problem..
The pics are of the interna l pattern of the TW-100
coupe333 is offline
post #7 of 16 Old 06-15-2002, 04:38 AM - Thread Starter
coupe333's Avatar
coupe333 is offline
post #8 of 16 Old 06-15-2002, 04:40 AM - Thread Starter
coupe333's Avatar
and this..
coupe333 is offline
post #9 of 16 Old 06-15-2002, 04:43 AM - Thread Starter
coupe333's Avatar
In reality the lines aro more visible...and more sharp..
coupe333 is offline
post #10 of 16 Old 06-15-2002, 09:29 AM
mltl's Avatar
muuuun,it looks like my old Mitsubishi sa51u,I think you can show this to your dealer,and ask him try another tw100 to make some compare.If the other tw100 have no this line,then you can ask for the new one.
and,if you can't change the tw100,not so good,IMO,you can try to use avia to set black/white balance,it can help you to reduce these lines.
Good luck.
mltl is offline
post #11 of 16 Old 06-15-2002, 11:18 AM
CKL
CKL's Avatar
It is a typical problem for some LCD projectors. I've seen 4 AE100 and 2 TW100 have such vertical banding. It seems that Epson panel is more serious than Sony panel. In my memory, Sony and Sanyo are not so serious.
CKL is offline
post #12 of 16 Old 06-15-2002, 11:29 AM
JPinTO's Avatar
A FLD filter helps alot with the banding on my AE100.
- JP in TOronto
JPinTO is offline
post #13 of 16 Old 06-15-2002, 12:00 PM
tahustvedt's Avatar
That's looks like vertical banding. A problem that is pretty normal with LCD-projectors and very distracting. I got rid of the vertical banding on my Hitachi by adjusting a setting in the servicemenu. I have a pretty long thread in the over $5000 forum.
How I got rid of the vertical banding:
http://www.avsforum.com/avs-vb/showt...hreadid=135347
How I got rid of the dead pixel:
http://www.avsforum.com/avs-vb/showt...hreadid=139111
How I fixed the color uniformity problem:
http://www.avsforum.com/avs-vb/showt...hreadid=136335
Tor Arne
tahustvedt is offline
post #14 of 16 Old 06-15-2002, 02:55 PM - Thread Starter
coupe333's Avatar
I noticed a Very strange thing, when the proj. is in FRONT projection mode the lines are less visible ,if the proj. is in FRONT CEILING mode they are sharper and more visible......
I am realy confused!...
coupe333 is offline
post #15 of 16 Old 06-15-2002, 11:30 PM
Li On's Avatar
Hi coupe333,
It's the same, just flipped horizontally so you may think the banding seems reducted a bit. That's also why I think it's somewhat source dependent...
regards,
Li On
Li On is offline
post #16 of 16 Old 06-16-2002, 04:01 AM - Thread Starter
coupe333's Avatar
Thanks to everybody!!...But i don't thin is source dependent because you can see these lines even with the internal pattern generator of the proj.
coupe333 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
