Dell 2300MP about. And dust problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-20-2013, 01:41 AM - Thread Starter
vorob1's Avatar
Hi, before i never used projectors so this is the first time. Ye, its kinda old but i'm happy with picture. What can you say about these specs? Especially comparing to modern projectors?
Code:
Single chip 0.7" Texas Instruments DLP™ technology
High contrast, double data rate (DDR) digital micro mirror device
True XGA, 1024 x 768 addressable pixels
4.7 lbs (2.14 kgs) lightweight compact design
2300 ANSI lumens brightness (Max)
2000:1 full on / full off contrast ratio
1.2x manual zoom lens
Built in 2W speaker
Auto image re-sizing (Auto-Sync) to 1024 x 768 full screen with scaling compression compatibility for UXGA, SXGA+, SXGA, XGA, SVGA, VGA, MAC
Preset and user defined video modes for optimum video and graphic settings
Self-diagnostic for video troubleshooting
State-of-the-art motion adaptive hardware deinterlacing with 3:2 and 2:2 pull down
200-watt user-replaceable UHP 2000-hour lamp
Eco Mode allows end user to extend lamp life to 2500 hours by reducing the lamp wattage and brightness
Full connectivity - Includes PC (VGA), S-Video, Composite Video, Component Video and RS-232 connectors
Monitor loop through to connect to PC monitor
Compatibility with Macintosh® computers
Compatibility with NTSC, NTSC4.43, PAL, PAL-M, PAL-N, SECAM, and HDTV (1080i, 720p, 576i/p,480i/p)
User-friendly, multi-language on-screen display (OSD)
Advanced electronic keystone correction
User-friendly control panel with backlight
Remote control and Dell drop-tested carrying case included
I got it for free, with 700hours lamp time. I'm projecting to white photo-background on wall. I'm getting 160cm picure.
The only problem i have with it, two white spots on picture:
Gess its dust somewhere inside, any guides or idead how to clean it?
P.S. Its even working on wall:
I'm using Sony XR500E, editing in Sony Vegas. And guys, sorry for my english, I'm Russian :)
vorob1 is offline
post #2 of 2 Old 05-24-2013, 01:14 AM
jnabq's Avatar
Liked: 39
jnabq is offline
Dell 2300mp Projector With 2300 Lumens Xga Resolution
