Ceiling Mount For Epson 8350? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-20-2013, 07:23 AM - Thread Starter
Mike4AU's Avatar
I just mounted my new Epson 8350 by using my existing NPL Series mount from Mount Direct. While the PJ can be mounted with the NPL Series mount, the metal extensions that one uses causes the PJ to be slanted and the adjustments on the mount will not correct the slant.
With the above in mind, I am going to see what other ceiling mounts are available and would appreciate your help.
Mike
Mike4AU is offline
post #2 of 4 Old 05-20-2013, 09:34 AM
Mr.G's Avatar
Quoted: 605 Post(s)
Liked: 311
Mike
Peerless PRGUNV Precision Gear Universal Projector Mount - Black
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 4 Old 05-20-2013, 05:25 PM - Thread Starter
Mike4AU's Avatar
Thanks, Mr. G! That is precisely what I need. Ordered it!
Mike
Mike4AU is offline
post #4 of 4 Old 05-25-2013, 10:00 AM - Thread Starter
Mike4AU's Avatar
I just mounted my PJ with the Peerless PRGUNV and it works like a champ. The mount is built like a tank and is extremely well engineered. The mount provides a lot of flexibility and the precision gears are really nice.
Thanks for the rec!
Mike
Mike4AU is offline
Epson Powerlite Home Cinema 8350
