Stepping into the projector world and need some advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-20-2013, 01:37 PM - Thread Starter
talos13's Avatar
I am looking to get a projector and screen and was wondering how big of a screen I would need to get? My viewing is 80% 2D and 20% 3D and my viewing distance is 13 feet. My room is not light controlled due to 2 windows in the room. I can always get curtains. I also need a projector and was also looking for some opinions. My budget for the screen and projector is around $2000 and under.
Thanks David
talos13 is offline
post #2 of 7 Old 05-20-2013, 01:42 PM
Verge2's Avatar
Quoted: 627 Post(s)
Liked: 151
Build your own screen for cheap. You can make it any size.
Verge2 is offline
post #3 of 7 Old 05-20-2013, 02:52 PM - Thread Starter
talos13's Avatar
Was looking for an actual screen size recommendation based on the distance.
talos13 is offline
post #4 of 7 Old 05-20-2013, 04:31 PM
petesvt's Avatar
Quoted: 13 Post(s)
I have a 100" fixed frame Elite Screens Cinewhilte with 1.1 gain 2 windows as well in my room, with curtains. I am sitting about 9' away from the screen and Im happy with the image. My projector is a BenQ W1070. My room is 11' x 13' in size. I got this projector because of the deal Newegg was running last month, now if I were looking I would wait to see reviews of the BenQ W1500 when it comes out. At your distance maybe a 110" at least.
petesvt is offline
post #5 of 7 Old 05-20-2013, 07:12 PM - Thread Starter
talos13's Avatar
I was looking at my room when I got home and I have two problems I forgot about. One is that I have a ceiling fan and i will need to be able to somehow have the projector mounted below the fan. The second problem is that my speakers are set up off center of the room. I guess I could fix this if I got a projector with both vertical and horizontal lens shift. I am looking at the Panasonic PT-AE8000U. Is there any other projectors that would be able to do what I need such as an Epson?
talos13 is offline
post #6 of 7 Old 05-20-2013, 08:55 PM
ondaedg's Avatar
ondaedg is offline
post #7 of 7 Old 05-21-2013, 09:06 AM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
Originally Posted by talos13 View Post
...my viewing distance is 13 feet
This is the part that matters.
Viewing distance * .66 = screen width.
13' * .66 = 104" wide screen.
This is the general rule for 'center of theater' feel. If you like sitting a bit closer than midway in a theater, then go a bit larger with your screen. If you like sitting a bit further away, then go smaller with the screen. Don't take a guess at what will be best, truly think about what you and your family like and where they like sitting in a theater. If you all like being close to the middle of the theater, then stick with the 104" width.
That works out to about a 120" diagonal 16:9 screen.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Benq W1070 1080p 3d Projector , Panasonic Ptae8000u Hd Projector
