replaced lamp on 8350 but no HDMI signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-21-2013, 03:07 PM - Thread Starter
calicoffee's Avatar
We just replaced the lamp in our 8350 epson pj and cannot get the HDMI signal. We can see the epson logo and menu display. Nothing else has changed with the connections to our home theater since the lamp went out. Any suggestions out there? Both power light and source light are on. Acc. to the manual, that means projection should work -- but we get the "no HDMI signal" prompt at the bottom left of the screen. Thanks in advance for any ideas anyone may have. We read this forum so much when figuring out what to buy.... but never joined until today!
calicoffee is offline
post #2 of 5 Old 05-21-2013, 03:21 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Try using your DVD or Blu-ray player with a 6 foot length of HDMI cable directly into the Epson 8350. First make sure your current connections are secure. If you get a full 1080p picture then something is up with your longer cable. Yes, they can get temperamental for no apparent reason.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 5 Old 05-21-2013, 03:36 PM - Thread Starter
calicoffee's Avatar
Wow, that's a GREAT idea. Will try that and post results.
post #4 of 5 Old 05-21-2013, 03:50 PM - Thread Starter
calicoffee's Avatar
WOW -- magic!!! That seems to have woken something up in the projector. We plugged in the DVD directly to the HDMI 1 input and got a full display (yippee). We then reconnected the regular HDMI cable which believe me we had tried many times to see if the connection was loose before doing this. But had gotten no results. Now, after the "jolt" from the DVD player, everything works. THANK YOU SO MUCH. This saved us a lot of trouble (and possibly a marriage). That's magic. Thank you. I guess this was a kind of electro shock therapy. Mr. G. you are a real genius. ( Sorry to lack originality there)
post #5 of 5 Old 05-22-2013, 08:06 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I'm glad the problem solved itself. Real Genius is a tip-of-the-hat to the 1985 movie (as are the bunny slippers) - not my IQ. wink.gif
Mr.G is offline
Epson Powerlite Home Cinema 8350
