Help...final projector selection!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-22-2013, 08:16 AM - Thread Starter
Birdie109's Avatar
I have been reading and reading on this site..SO MUCH good material on here!!!! I was dead set on getting the Epson 8350 and then I found the Benq 1070 might be a contender as well!! I am looking for something portable because I would like to take it camping or use at my house as well. At my house I live in a neighborhood but the back of my house faces the common land so its pretty dark and my house blocks the street lighting. I would say 3-5 foot candles in the backyard. I am looking at getting the 144" diagonal screen from www.campchef. I also have about 30-35 ft from the screen to where I could put the projector. With that being said....what should be my choice????
Birdie109 is offline
post #2 of 2 Old 05-24-2013, 12:17 AM
jnabq's Avatar
Liked: 39
You want to project onto the back of the house? The Benq has lots of brightness, but has a shorter throw distance and limited placement flexibility, compared to the Epson. Both good pj's in that price range, you just need to narrow down the requirements.
jnabq is offline
Epson Powerlite Home Cinema 8350 , Benq W1070 1080p 3d Projector
