HC4000 - AVS Forum
post #1 of 7 Old 05-27-2013, 03:55 PM - Thread Starter
dinosaur1's Avatar
I sit about 11 feet from the tv. Would a projector work out in our basement rec room? Costco has a great deal on the projector and screen? It this a good screen that they are offering in the bundle?
http://m.costco.com/Mitsubishi-HC4000-Home-Theater-Projector-Bundle.product.11755444.html
dinosaur1 is offline
post #2 of 7 Old 05-27-2013, 04:37 PM
Verge2's Avatar
Quoted: 23 Post(s)
Should work fine
Verge2 is offline
post #3 of 7 Old 05-27-2013, 04:48 PM - Thread Starter
dinosaur1's Avatar
Originally Posted by Verge2 View Post
Should work fine
My next step is speakers. Speaker stands or speakers attached on the wall? What kind...Bose?
post #4 of 7 Old 05-27-2013, 05:45 PM
Verge2's Avatar
Quoted: 23 Post(s)
No Bose, not them.
Verge2 is offline
post #5 of 7 Old 05-27-2013, 06:07 PM - Thread Starter
dinosaur1's Avatar
No Bose, not them.
What do you suggest for my set up?
post #6 of 7 Old 05-28-2013, 12:28 AM
jnabq's Avatar
Liked: 39
Don't know if it's a "great" deal. Not incl shipping total costs is about, $1175 for those two items off the 'net, where costco deal is $1200? I guess you get costco's return advantage, and might save a dollar or 2 on shipping. I'd be concerned with a pull down type screen as they can sometimes become a bit "wavy", but they tend to be less expensive. For that 106" screen, you'd have to mount the pj from app. 10'-16' from the screen with a min ceiling height of about 8' 3". Does that work? You can use Coder's Calc to look at some lumen numbers at those different distances. http://www.eliteprojectorcalculator.com/
jnabq is offline
post #7 of 7 Old 05-28-2013, 02:47 AM
SomeCreepinaVan's Avatar
Yeah, that would work.
I would get the Mits HC7800D over the HC4000. It's newer and comes with 3D ane costs 1300. The 4000 is great but has been out for a long time and the price hasn't gone down.
For speakers I would have you check out the Pioneer SP-FS52 towers at $200 apair. Bose speakers are overprised and not very good. It's like a home theater in a box setup that's bascically tiny tv speakers surrounding you.
There's a good review of the Pioneer speakers on www.hometheaterreview.com
SomeCreepinaVan is offline
Mitsubishi Hc4000 300 Inch 1080p Front Projector , Mitsubishi Hc7800d Projector Full Hd 3d Projector
Gear in this thread - Hc4000 by PriceGrabber.com
