Optoma HD25 -LV or Optoma HD25 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-29-2013, 10:21 AM - Thread Starter
Anilak's Avatar
It might be silly question, but want to make sure $300 extra is worth.
I recently ordered Optoma HD25-LV and i received it. As it is exactly looks like Optoma HD25 and not sure how to validate it is Optoma HD25 lv and not Optoma HD25. This is my first Projector hence i do not have much information.
Reason I am asking is when I gone through the Manuals, thee is button AV mute, and instead of that I have ? on the button, which is HELP. Got little confused
Anilak is offline
post #2 of 4 Old 05-29-2013, 02:23 PM
urbeenjammin's Avatar
Quoted: 66 Post(s)
The easy way to validate is thru the speakers.Just go to the menu and see if it has options for audio.The regular HD version has no audio.
urbeenjammin is offline
post #3 of 4 Old 05-30-2013, 11:08 AM - Thread Starter
Anilak's Avatar
oh!, Thanks. Yes, there is an Audio option. MENU->Setting->Audio setting.
Anilak is offline
post #4 of 4 Old 05-31-2013, 07:29 AM
jamnperry's Avatar
The HD25 also has audio option. Only difference there is 10w vs 16w for the LV.
Sounds like the remote is different though. I have no button with a ? but does have volume . It's silver. This is for the HD25
jamnperry is offline
Optoma Hd25 Lv 3d Home Theater Projector , Optoma Hd25 Hd 3d Home Theater Projector
