video essentials DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-14-2002, 09:46 AM - Thread Starter
iamjim's Avatar
Please,
Can someone tell me where to get a CD that is supposed to help you calibrate your Home Theater Projector?
One is called Video Essentials ande the other is called AVIA GUIDE TO H.T.
I am new and clueless.
I am buying a NEC 650 (got an incredible price) and I think that these CD'S MIGHT HELP MAKE THE PICTURE LOOK BETTER.
JIM
iamjim is offline
post #2 of 9 Old 06-14-2002, 10:07 AM
Larry Davis's Avatar
I have used Avia. I haven't tried Video Essentials, which I have heard is more geared for CRT's. You could get it from amazon.com but it might pay off to visit some other online DVD retailers. These DVD's aren't cheap.
Larry Davis is offline
post #3 of 9 Old 06-14-2002, 10:22 AM - Thread Starter
iamjim's Avatar
did you feel Avai Guide To H.T. helped the picture quality
would it be helpful for a NEC650 ?
iamjim is offline
post #4 of 9 Old 06-14-2002, 10:37 AM
Yes, it definitely did help. Is this a CRT front projector? Those need much more fine tuning than a digital projector.
post #5 of 9 Old 06-14-2002, 12:35 PM - Thread Starter
iamjim's Avatar
no,
it is a LCD Projector (NECVT650)
iamjim is offline
post #6 of 9 Old 06-14-2002, 12:55 PM
da_burl's Avatar
I got mine (Avia) from Amazon, good service, fast shipping, (no affiliation, blah).
Normally, I point people from over "there" to forums over "here", but this is an exception. The *************** (do the www and the dot com thing), has an entire forum dedicated to Avia and VE. I have seen posts that people have gotten it at Best Buy, CC, Frye's, etc. They say it might not be in an obvious spot, like in the regular movies under the letter "A" for example.
Avia or I suppose VE is almost essential for getting a good calibration. I couldn't believe the difference it made for me, after trying to eyeball it. And Avia does have some special sections for "special" display devices, such as lcd's.
Also, there are now at least two versions of Avia, I think you are talking about the "new" one, with the demo/explanation parts. I think the first one was purely business, you had to know which chapters to use, etc.
da_burl is offline
post #7 of 9 Old 06-14-2002, 01:07 PM
I think Avia is the better disc choice for an LCD projector. I am going to move this to the Digital Projectors Under $5000 forum. Hopefully some of the experts there can give you advice on the best way to use it with your LCD.
post #8 of 9 Old 06-14-2002, 01:22 PM
erdc's Avatar
Which one would be good for DLP?
erdc is offline
post #9 of 9 Old 06-14-2002, 01:54 PM
robertmee's Avatar
If you don't want to spring for the cash initially for Avia, you can use the THX setup on several DVD's. This setup steps you through properly setting your contrast, brightness, color, tint, etc. It has decent test patterns and is a start. T2:UE and Star Wars both have it I believe.
robertmee is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
