Nvidia 3d Vision support on the LG PA75U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-10-2013, 08:49 PM - Thread Starter
Jonathan Hersey's Avatar
So you can force 120hz with EDID hacks to make Nvidia 3d vision work with lots of displays
What about the LG series of DLP 3D Projectors? I am getting the HDMI 1.4 standard LG PA75U unit and In the manual it supports single frame sequential and tons of other modes for 3d as well SBS T&B Field Alt, etc… Will using an EDID hack or bending the EDID pins work with any projector? Even the LG one I mentioned? I wonder if the PA75U supports undocumented 120hz modes like the Older HDMI 1.3 series LG PA70G… Any info would be awesome! thanks guys!
Jonathan Hersey is offline
Lg Pa75u Dlp Home Theater Projector
