AE100 16:9 mode is -/- 15% lumens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-15-2002, 02:13 AM - Thread Starter
Erikro's Avatar
Question: Do i miss something?
AE100 = 700 lumens 800x600, but when i use the 16:9 mode 848X480.
Isn't it only 595 lumens, because it must be blocking 15% of the light.
I hope i am wrong here, i need the lumens for a good 2.5 meter wide image
Btw when using 16:9 mode don't you get grey/black borders under and above the image on the screen?
Erikro is offline
post #2 of 8 Old 06-15-2002, 05:14 AM
John McLean's Avatar
I do not notice any light loss from the AE100 when projecting 16X9 material. Yes you have the gray bars when you project 2:35 and the bars are not there for 1:85 (my favorite) and 1:78.
John
John McLean is offline
post #3 of 8 Old 06-15-2002, 06:12 AM
JPinTO's Avatar
Not true.... the AE100's full panel is 856x480 @ 700 lumen.
Showing 2.35:1 AR films uses 75% of the panel for 525 lumen.
By comparison a 1000 lumen XGA 4:3 projector running at 16:9 (1.77:1) outputs 750 lumen. XGA projector showing 2.35:1 AR films uses 56% of it's panel, for lumen of 560.
So a 700 lumen AE100 is equivalent to a 1000 lumen XGA projector in widescreen use.
- JP in TOronto
JPinTO is offline
post #4 of 8 Old 06-15-2002, 11:18 AM - Thread Starter
Erikro's Avatar
You are right, i was confused by the term SVGA. Everywhere they say it uses a SVGA panel. SVGA is normally 800x600, it would be fairer if they had called it WVGA (it is 848x480 instead of 640x480).
Erikro is offline
post #5 of 8 Old 06-15-2002, 11:32 AM
Namlemez's Avatar
I don't know, everywhere I see it is listed as WVGA. Who has it incorrectly?
http://www.projectorcentral.com/proj...m?part_id=1488
http://shop.store.yahoo.com/electron.../panthae1.html
Namlemez is offline
post #6 of 8 Old 06-15-2002, 11:48 AM
tahustvedt's Avatar
I've seen it listed incorrectly as SVGA several times on stupid webshops. :)
On a 4:3-projector, although the amount of light from is decreased when running in 16:9 mode the brightness is still the same. What I mean is that the whites are still just as bright.
The same goes for a 16:9-projector (like the AE100) running in 4:3 mode with black bars on the sides.
Tor Arne
tahustvedt is offline
post #7 of 8 Old 06-15-2002, 12:00 PM
JPinTO's Avatar
Most places call it correct WVGA... it's definitely an error to call it SVGA.
- JP in TOronto
JPinTO is offline
post #8 of 8 Old 06-15-2002, 01:50 PM - Thread Starter
Erikro's Avatar
Erikro is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
