Help me buy the correct screen and projector!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-15-2002, 07:56 AM - Thread Starter
2thdoc01's Avatar
Quoted: 16 Post(s)
Hi,
My name is Kurt, I am a newbie!
There now that this is out I will give you the details.
I am having my basement finished now and need advice on proper setup for my HT.
I have a room in the basement that has 2 -36 in windows in the corner. The room is 15 ft wide by 30 ft deep. I will plan on seating being max of 16 ft from wall. Ceiling ht will be 7 ft 6 in.
The screen area will be boxed in with square pillars giving an opening of 6 ft wide by 7 ft tall. {See pic} The screen will be set in to the left of the windows. The soffit will cover the pipe with sq columns on each side. The windows will need a dark window treatmnet of some kind.
What size screen should be used with this size room, seating and screen opening??
I will use the setup with digital cable that has hdtv available stations, and for DVD movies. If I didnt get a completely dark room...ie for news at 10...what type screen do I need and which projector is less affected by the light?
As for cable routing...any good ideas on how to run a long way for remote operation?
Other feedback is appreciated!!
Thanks!!
Kurt
2thdoc01 is offline
post #2 of 2 Old 06-17-2002, 01:01 PM
Ron AZ's Avatar
Kurt.. I would recommend you visit the "THEATER CONSTRUCTION" , "SCREENS" and "DIGITAL PROJECTORS" -both the under and over the $5,000 and research all the postings there for the past 3 months at least under all 4 sections. You will find a lot of very useful information, regarding theater construction, screens. various types of projectors and other HT related issues. You can be sure to find answers (opinions, I should say) to every question you have regarding the construction of your room and the equipment you want to buy. I would recommend you visit as many HT sores to audition equipment and to view their set-ups...but...TAKE YOUR TIME... and have fun doing it... Ron AZ
Ron AZ is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
