acer h 5360 projector screen flickers blue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-13-2013, 11:10 PM - Thread Starter
saucow4's Avatar
my acer h5360 every few minutes the screen will flicker blue in the middle of a movie. i just put a new bulb into it and it still does it. anyone know whats up with it or how to fix it thanks
saucow4 is offline
post #2 of 3 Old 06-14-2013, 09:17 PM
blackoper's Avatar
Quoted: 17 Post(s)
Does it do this with all video sources or just the one for movies? Not enough info for anyone to diagnose
blackoper is offline
post #3 of 3 Old 06-15-2013, 04:26 AM
DragonSixGolf's Avatar
Liked: 25
DLPs flash colors sometimes as a result of the colorwheel sensor being dusty. You could carefully try to blow out/vacuum dust using clean, dry compressed air. did you replace the bulb to "fix" the color flashes.. or was it doing it already?
here's a different model but same basic idea http://www.instructables.com/id/Disassemble-and-Clean-an-Optoma-HD70-Projector/
google has 100s of hits on dlp flashing blue
DragonSixGolf is offline
Acer H5360 3d Dlp Projector
