BENQ W1080ST's 3D...too dark? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-15-2013, 05:44 PM - Thread Starter
Ghostman84's Avatar
Is it just me? It just seems so much darker than the 2D picture. It's also significantly darker than my passive 3D LCD TV.
I've got the newest BENQ DLP Link glasses, so what gives?
Ghostman84 is offline
post #2 of 5 Old 06-15-2013, 10:53 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
3D is always much darker than 2D
LCD's are brighter than projectors
those are the sacrifices you have to deal with. try a higher bulb brightness if available
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #3 of 5 Old 06-16-2013, 05:17 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
How big a screen do you have? The Benq is one of the brightest 3D projectors out there. Just look at some of the others. If you have ever seen 3D in movie theaters it is often darker than what you will get the 1070/1080 Benq.
rwestley is offline
post #4 of 5 Old 06-16-2013, 09:31 PM - Thread Starter
Ghostman84's Avatar
I have a 120' screen. I feel better just reading that it's one of the brightest.
I'm going from a 32' passive LCD so I'm sure I need to adjust.
Plus, I need to calibrate (just don't want to spend big bucks on a meter).
Is it the glasses maybe? I have the latest BENQ DLP glasses...are their any better alternatives?
post #5 of 5 Old 06-19-2013, 01:23 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The BENQ glasses are fine. Be sure the room is light controlled (really dark) and that you are using high lamp mode for 3d. This should be automatic. A 120" screen is considered large but it should be ok even with 3D. You will have to get used to it compared to a very bright small LCD.
rwestley is offline
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
