Which Projector? Optoma HD25, Hd25LV, or gt750e?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-16-2013, 07:58 AM - Thread Starter
Drew Murphy's Avatar
Im a newbie to this, but i do have a projector made for presentations that i currently use but looks like crap for what i do.
I am looking for a projector that is good for gamming and movies, i know the gt750e has 120hz refresh rate not sure about the rest. im really not sure if i want the HD25 OR HD25LV i will be doing some 3d (possibly) so any advice will be appreciated.
Drew Murphy is offline
post #2 of 5 Old 06-16-2013, 01:25 PM
jamnperry's Avatar
Need more info like size and type of screen and light controlled room or not.
jamnperry is offline
post #3 of 5 Old 06-16-2013, 06:09 PM - Thread Starter
The size of the screen i have no idea, its just a white sheet tacked onto a 2x4 frammed wall... and its a basement so it has to relly mini windows near top of room. but they r bother coverd up to there is no light when projector is on... i am planmning to get a bose cinemante gs series 2 and hooke that up to the projector along with a ps3,xbox computer and cable.. would like 1080p and rally good quaility thanks
post #4 of 5 Old 06-16-2013, 06:29 PM
jamnperry's Avatar
Short answer: HD25 would be perfect but you really need to do more homework.. Like how far from the screen and when you do put up a screen, how big do you want it. You really can't go into this without determining more precisely what you want.
post #5 of 5 Old 06-16-2013, 07:28 PM - Thread Starter
Short answer: HD25 would be perfect but you really need to do more homework.. Like how far from the screen and when you do put up a screen, how big do you want it. You really can't go into this without determining more precisely what you want.[/quote
OK I wilo look into it but here is the problem, sound, the projector has sound in and out, the bose only has optical and RCA witich the projector die sent have so I'll have to use some kind if y cable?? But like if I plug it Ito audio 1 will that cover every devices sound plugged in or will I have to manual switch it for each devise? Thanks
Optoma Hd25 Lv 3d Home Theater Projector
