12x19 dedicated room, is the MITSUBISHI HC7800D for movies & games - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-18-2013, 06:11 PM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
This seems to be the one to get in my price point ($1000-1500). I had been looking at the BENQ 1070 trying to keep it under $1000, but I want this to be a great theater.
My main use will be movies and Xbox games (well, maybe Playstation if Xbox keeps it up). I do want good 3D.
The room is dedicated, 12x19 so no light issues.
It will be ceiling mounted and I'm thinking 110-120" fixed screen.
NewEgg has this for $1150 right now.
Any others that I should look at first?
My Amex extends the warrantee one year, but should I get the 2 year extended?
mbuck is offline
post #2 of 4 Old 06-18-2013, 06:27 PM
AV_Integrated's Avatar
Quoted: 973 Post(s)
Liked: 718
I would consider the BenQ W7000 as well which can be had for around $1,500...
http://www.rythercamera.com/catalog/product_info.php?csv=gg&products_id=45554
Very good black level performance and solid brightness from this model which helps it to shine in a proper theater environment.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 06-18-2013, 06:45 PM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
The W7000 along with the 7800D are on the top of my list. Choosing this is so much more difficult as I can't try them like I did my speaker setup.
I can get the 7800D for $1100 right now. Do you know the differences/benefits between these two?
mbuck is offline
post #4 of 4 Old 06-18-2013, 09:13 PM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
If I stepped up by $1000, so say a $2500 projector...what kind of difference will I see? I want a great picture, I don't want to "settle" especially at $1500.
mbuck is offline
Mitsubishi Hc7800d Projector Full Hd 3d Projector
