My first projector and i need help!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-19-2013, 08:19 PM - Thread Starter
angrybananas's Avatar
i would want a projector that's HD and is really capable of playing outdoors ill be using it to display video games (xbox360,PS3, PC) in HD, something under $600 and that can be seen day and night, reliable, durable and easy to use. your recommendation are appreciated smile.gif
angrybananas is offline
post #2 of 6 Old 06-19-2013, 10:07 PM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
A projector isn't going to work outdoors in the daytime. Even indoors with too much reflective or ambient light will be a compromise. You can use a projector in less than optimal conditions but you need to be realistic about the limitations.
Sonyad is offline
post #3 of 6 Old 06-19-2013, 10:09 PM - Thread Starter
Night seems realistic now lol any recommendation
post #4 of 6 Old 06-19-2013, 10:17 PM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
For gaming and portability I would recommend the Optoma gt750.
Sonyad is offline
post #5 of 6 Old 06-19-2013, 11:13 PM - Thread Starter
post #6 of 6 Old 06-20-2013, 01:52 PM
jnabq's Avatar
Liked: 39
Good for data, sure, but has (RBE) rainbows in video. http://www.pcmag.com/article2/0,2817,2416027,00.asp If your trying to keep it lower cost, maybe the Acer k330 would be an option if your environment is kept dark and the image isn't real big. http://www.avsforum.com/t/1344147/acer-k330-led-1280x800
However getting 3d on it might require you to jump through some hoops.
http://www.avsforum.com/t/1374337/acer-k330-how-to-get-the-3d-picture#post_22450621
jnabq is offline
Optoma Gt750 Projector , Acer K330 Portable Home Theater Projector
