Connecting a projector to a PC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-23-2013, 10:05 PM - Thread Starter
wine monkey's Avatar
My computer is pretty old and has no other input/output ports besides 2 DVI connections on the video card.
I was wondering what would be the best way to connect my computer to a typical projector (that I will be buying soon;))? Would a DVI to HDMI cable work and if so how would that effect the overall image quality?
wine monkey is offline
post #2 of 3 Old 06-23-2013, 11:32 PM
SiggUA's Avatar
Liked: 25
A passive DVI to HDMI converter works and will provide the best possible quality. Single link DVI-D and HDMI carry identical signals, the difference is only mechanical.
SiggUA is offline
post #3 of 3 Old 06-24-2013, 08:00 AM
mullet34's Avatar
You could also use a DVI to VGA adapter if you get a projector that doesn't have HDMI inputs.
mullet34 is offline
