Recommendations for 2800 lumen, 21.5' throw distance, 4:3, 143" diagonal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-24-2013, 12:23 PM - Thread Starter
youthman's Avatar
Quoted: 63 Post(s)
Liked: 277
I'm replacing our projector in our youth ministry building (was the old sanctuary).
Last week I purchased the Epson EX7210. It fit within our <$700 budget, it had 4:3, was 2800 lumens....seemed like a great fit.
The biggest issue was that when I put the projector in 4:3, you could clearly see extra light beyond the 4:3 box. Every aspect ratio other than 16:9 did this. We have a Viewsonic that when you switch from 4:3 to 16:9, there is no light that extends beyond the 4:3 box.
On top of the fact that we had major light bleeding beyond our screen and onto the walls and stage decorations, the 4:3 image was way too small and the other formats were too large for the screen.
So now I'm on a quest for a native 4:3 projector that has close to a 21.5' throw and will fill a 143" screen.
Looking at the calculator pro on Projector Central, the Epson EX7210 has a throw ratio of 1.30 - 1.56. Would I need to find a projector that has a higher throw than 1.56 or something that has a better zoom range?
Any suggestions?
youthman is offline
post #3 of 9 Old 06-24-2013, 12:43 PM - Thread Starter
youthman's Avatar
Quoted: 63 Post(s)
Liked: 277
Any thoughts on the above projectors? Any I should avoid? I've read great things about the Epson even though it would be slightly above budget....but it's doable.
youthman is offline
post #4 of 9 Old 06-24-2013, 01:10 PM - Thread Starter
youthman's Avatar
Quoted: 63 Post(s)
Liked: 277
I just found the Epson 905 Refurbished for $300 less and Free Shipping on the Epson website than the price at BB. Only downfall is there is no returns on Refurbs.
I just called Epson to verify that it would work for our application and based on their calculator http://www.epson.com/alf_upload/landing/distance-calculator/ it will be close but if the specs are correct, it will work.
Do you think this is a safe purchase? Just would hate to buy it and not be able to return it if it doesn't fill our screen or the image spills beyond our screen.
youthman is offline
post #5 of 9 Old 06-24-2013, 09:50 PM
jnabq's Avatar
Liked: 39
I'd be hesitant to buy a refurb from Epson atm. Their qc has been a little lacking, and there is a good chance you might not get a good unit. Is it worth $300 less? I don't think I would chance it. Better to buy new so if you have any issues, they'll be taken care of.
jnabq is offline
post #6 of 9 Old 06-25-2013, 07:58 AM - Thread Starter
youthman's Avatar
Quoted: 63 Post(s)
Liked: 277
Thx for the suggestion jnabq. Just curious why you would purchase a new vs a refurb. They both carry the same 2 Yr warranty and the refurb has a new bulb. The only difference is I just can't return it unless it's defective. With the new, I could return it if I just wasn't satisfied with it or if it didn't meet our needs.
youthman is offline
post #7 of 9 Old 06-26-2013, 10:19 PM
jnabq's Avatar
Liked: 39
Totally your choice, and if saving $300 is more important than the time/effort you MAY have to spend dealing with the "refurb runaround", then sure, go for the refurb.
jnabq is offline
post #8 of 9 Old 06-26-2013, 10:28 PM - Thread Starter
youthman's Avatar
Quoted: 63 Post(s)
Liked: 277
Thanks. Yesterday, I decided to order the refurb. If it were $50 savings, I would have went with a new unit but $300 is a significant enough savings for me to give it a shot. It arrives Friday. Will let you know how it turns out.
youthman is offline
post #9 of 9 Old 06-26-2013, 10:42 PM
jnabq's Avatar
Liked: 39
Cool, hope it turns out well for ya!
jnabq is offline
Epson Ex7210 Wxga Multimedia 3lcd Projector , Epson Powerlite 905 Multimedia Projector 3000 Lumens Xga 1024 X 768 Pixels Ultra Bright Images
