is 7 foot ceiling enough if I'm using the BM5001U ceiling mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-26-2013, 01:46 PM - Thread Starter
majikmann's Avatar
I just moved and unfortunately the only house I could find in the area that was suitable for our needs has the basement ceiling at 7feet the last place was 9feet... I have the BM5001U mount: is 7 feet high enough?? the top of the screen has to be 8" below the center of the lens, so I'm wondering if the screen might be too low.
My upstairs ceiling is 9 feet, but I really want to have my man cave as lighting is easily controlled there. Any suggestions? I'd like to rest the top of the screen on along the ceiling, but unfortunately the hd20 doesn't have lens shift.
Does anyone else have a 7 foot ceiling setup with a ceiling mounted HD20?
Sorry, forgot to mention that I have a 100" fixed EliteScreen and would like to continue using the full screen.
majikmann is offline
post #2 of 9 Old 06-26-2013, 01:54 PM
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
Curious to hear...I have hd3300 and 7' ceiling. I think we ordered a universal mount from best buy. Idk which one
megdagooch is offline
post #3 of 9 Old 06-26-2013, 02:06 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
With the HD20 or any fixed offset projector without lens shift you are not going to be able to ceiling mount the projector AND have the top of the image abut the ceiling.
You can table mount the projector and have the image all the way to the ceiling or you can ceiling mount and have the screen be below the ceiling. You can't have both of these things unless you are willing to change projectors.
If you are concerned about whether the projector will simply hang too low in the room... that depends on your room, traffic patterns and aesthetic requirements but all of those are independent of the technical limitations of the HD20 placement options.
walterappleby is offline
post #4 of 9 Old 06-26-2013, 02:08 PM
Quoted: 25 Post(s)
Liked: 77
Regardless of the mount the same issues apply to the HD3300 due to the fixed offset.
post #5 of 9 Old 06-26-2013, 02:13 PM - Thread Starter
majikmann's Avatar
Thanks for the reply. It looks like the screen will be really low to the ground. Especially since I will have a home cinema setup with risers for the back row seats. this kinda sux. lol
post #6 of 9 Old 06-26-2013, 02:18 PM
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
That's was what I thought
post #7 of 9 Old 06-26-2013, 02:30 PM - Thread Starter
majikmann's Avatar
anyone else ever run into this? any solutions?
post #8 of 9 Old 06-26-2013, 03:05 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
You could always angle the projector up and correct the resulting keystone with the digital keystone (I am sure I will hear a lot of flack from you purist out there but its not a mortal sin). Or you could also angle the screen down to correct the keystone without using digital correction. Its cheaper than buying a projector with vertical lens shift or then again maybe its a good excuse for an upgrade
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #9 of 9 Old 06-28-2013, 10:08 AM - Thread Starter
majikmann's Avatar
Actually I found a great solution! I bought the Optoma 5001U ceiling mount from peerless mounts... and wouldn't you know, you can adjust the projector angle!! It worked perfectly! I'll post pics later. So if you have a low ceiling this is the way to go with the HD20..
