looking for 3d projector for living room. 13 ft throw. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-27-2013, 04:05 PM - Thread Starter
jorge007's Avatar
Quoted: 31 Post(s)
My room will be light controlled.I would like to shelf mount it on the back wall the sofa also sits against the back wall. It us about 13 ti 14ft from the front wall.
I want to project about 90 inc image or bigger but i think that i am really close. Would like 3d that Works like the pa75u. My budget is around. 700.00
jorge007 is offline
post #2 of 3 Old 06-27-2013, 04:24 PM
Psythik's Avatar
Well if you want 1080p, your only options within your budget are the Acer H6510BD & ViewSonic PJD7820HD. Both might be a bit too bright for a light-controlled room and I don't know how 3D works in the PA75U. Therefore you'd have to settle for 720p unless you add about $500 to your budget. I'd advise against anything lower than 1080p for large screens unless you sit 20+ ft away:
Psythik is offline
post #3 of 3 Old 06-28-2013, 02:40 PM
CHIA's Avatar
The new Optoma HD25 3D projector, for under $1k will work with a 106" screen, between 11'6" and 13'10".
The calculator uses an HD33, but I think I read that the zoom and offset are the same for the HD25.
Made a ceiling height assumption of 8'. Based on experience, that's a nice size screen too.
CHIA is offline
Acer H6510bd Dlp 3d Projector , Viewsonic Pjd7820hd Full Hd 1080p Projector , Lg Pa75u Dlp Home Theater Projector , Optoma Hd25 Hd 3d Home Theater Projector , Optoma Hd33 3d Ready Dlp Projector
