Viviitek H1185HD ISFccc version of the H1180HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-01-2013, 02:55 PM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
A second version of the H1180HD will come out this fall from Vivitek. The H1185HD will offer more lumens (2500 instead of 2000) and also an ISFccc certification.
http://www.projection-homecinema.fr/2013/07/01/vivitek-h1185hd-version-isfccc-du-h1180hd/
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
post #2 of 9 Old 07-01-2013, 03:23 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
ISFccc means nothing really.. to lean more read here..
http://www.avsforum.com/t/1478977/calibration-without-isfccc-options/0_100
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 9 Old 01-18-2014, 03:10 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Just got mine, review will come out soon after my review of the SONY VPL-VW1100ES :
http://www.projection-homecinema.fr/2014/01/18/vivitek-h1185hd-dlp-full-hd-isf-et-3d-ready-reception-du-projecteur-pour-un-futur-test/
kraine is offline
post #4 of 9 Old 01-18-2014, 12:55 PM
swedish cook's Avatar
I'd like to see the comparison to the Infocus IN8606HD, its obviously the same base unit, same headline specs including weight and massive zoom. But I notice Infocus are claiming 1000 extra hours.
Edit - looks like the noise levels are different also.
Vivitek H1180HD - 2000 lumen 29db eco 33db std, life 6000 eco or 4500 std
Vivitek H1185HD - 2500 lumen 32db eco 35 db std, life 5000 eco or 5000 std
Infocus IN8606HD - 2500 lumens 29db eco 33 db std, life 6000 eco or 4500 std
Vivitek offering extra year warranty though, interesting. I must say that I tried the IN8606HD on std and the noise was real bad, made for deaf people imho, mine is staying on eco.
Spec sheets:
http://www.vivitek.co.uk/pdfs/Vivitek_H1180HD_Datasheet.pdf
http://www.vivitek.co.uk/pdfs/Vivitek_H1185HD_Datasheet.pdf
http://www.infocus.com/sites/default/files/InFocus-IN8606HD-3D-Projector-Datasheet-EU_1.pdf
swedish cook is offline
post #5 of 9 Old 01-19-2014, 03:02 AM
Looked in my Infocus IN8606HD box for evidence, not much in there but the label on the HDMI cable supplies further confirmation if needed of a common manufacturer, its labelled as a "Qumi" cable (as in Vivitek LED projector Qumi).
Looked again at the french site you linked to the onscreen menus of the 1180 unit are exactly like mine
http://translate.google.co.uk/translate?hl=en&sl=fr&u=http://www.projection-homecinema.fr/2013/06/29/vivitek-h1180hd-test-projecteur-en-exclusivite-sur-projection-homecinema-fr/&prev=/search%3Fq%3Dvivtek%2B1180%2Breview%26espv%3D210%26es_sm%3D93%26biw%3D1024%26bih%3D678
They are subtly different models of the same unit, co-manufactured.
post #6 of 9 Old 01-19-2014, 09:18 AM
sportster64's Avatar
Cook, wHat are the black levels like with the infocus,
sportster64 is offline
post #7 of 9 Old 01-19-2014, 03:28 PM
Very happy personally, with the IN8606HD, as a previous owner of an Optoma H27 and Infocus X10. Guess we need to await a professional review. As ever you need to tweak the brightness, contrast and saturation to suit your taste, initally I hiked up the brightness too much and then yes the blacks were poor then.
I have a Panasonic LCD TV next to it and if I have them both on, yes the blacks are deeper on the TV, thats only what you expect though, but there is a world of difference though versus the old X10, I really avoided ever comparing the TV and projector picture as the X10 was so dim in comparison it was unbearable - it really shows how far budget projectors have come in the last couple of years.
Its not like I had an extensive choiceanyway, I needed a unit to fit existing mounting and screen, a throw ratio of 2.07.
post #8 of 9 Old 02-01-2014, 02:51 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
The full review about the Vivitek H1185HD is now online :
http://www.projection-homecinema.fr/2014/02/01/test-vivitek-h1185hd/
kraine is offline
post #9 of 9 Old 03-20-2014, 07:07 AM
weblogic's Avatar
Hmm...VIVITEK H1185HD has hdmi 1.4b support by the spec.
Can it run 1080p60 per Eye (120 Hz total)?
weblogic is offline
