can't access menu for brightness in Epson 8700UB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-02-2013, 02:08 PM - Thread Starter
IPT
IPT's Avatar
hey people - long time no see ...I've been enjoying my movies and not on here in quite some time. Anyway, my Epson 8700UB has been working great for sometime now. I have 1200+ hrs on it and I need to bump up the brightness. When I use the remote the "image" and "signal" areas of the menu are grayed out and I cannot select them. I can change the other settings. If I press the "color mode" button on the remote nothing happens. What am I missing? Do I have something set blocking from accessing these areas? How can I bump up my brightness?
IPT is offline
post #2 of 2 Old 07-02-2013, 04:44 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Have your perused the users manual lately? Typically you can not change these settings if you are currently not sending a signal to the projector but other than that, check the instructions.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Epson Home Cinema 8700 Ub Projector
