Can I use 3M adhesive tape to ceiling mount projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-04-2013, 03:06 PM - Thread Starter
Percuvius's Avatar
Hey guys, just wondering if anyone has ever used 3M double sided adhesive to affix their projector mount to the ceiling?
Percuvius is offline
post #2 of 10 Old 07-04-2013, 03:35 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
this sounds like a really bad idea...
I mean, I've had pictures fall off the wall using double side tape, forget a 30lbs, 1000+ dollar projector hanging over my head
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #3 of 10 Old 07-04-2013, 03:52 PM - Thread Starter
Percuvius's Avatar
post #4 of 10 Old 07-04-2013, 05:41 PM
nickoakdl's Avatar
Quoted: 76 Post(s)
Liked: 62
Horrible idea. It might stick for a short time, but some day you'll come home to a broken projector on your floor.
nickoakdl is offline
post #5 of 10 Old 07-04-2013, 06:23 PM
///3oris's Avatar
You could, considering some projectors weigh right around 6 lbs or less, but unfortunately you're not affixing it to the "ceiling;" it'll be stuck onto the paint on the ceiling. I think it's a terrible idea, but you could, if you don't mind one day potentially seeing your projector in pieces on the floor smile.gif.
Get a mount, they can be had for as little as ~$10. Good ones start at right around $70-90 on sale.
Internet Certified Electrical Engineer
"I am just looking for an honest man."
///3oris is offline
post #6 of 10 Old 07-05-2013, 03:12 PM
Tinman's Avatar
Liked: 33
ALL adhesives eventually fail. It's just a matter of time.
Welcome to the darkside.....
Tinman is offline
post #7 of 10 Old 07-05-2013, 05:45 PM
Highjinx's Avatar
Quoted: 323 Post(s)
Liked: 152
The adhesive is only as strong as the substrate it bonds to.........
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
post #8 of 10 Old 07-06-2013, 04:47 PM
TrickMcKaha's Avatar
You would want a tether attached more securely to catch the projector when/if it falls. With that, go for it. You could even use Velcro tape in order to allow repositioning.
I have attached go pro cameras to my gokart with 3M adhesive tape and never needed the tether. But I did have a tether.
Don't see the advantage of tape over screws, though. Screws into the ceiling are probably easier and less messy.
If what you have is a drywall or popcorn ceiling, those helix shaped drywall mount screws really work well. You don't need any solid wood to screw in to.
TrickMcKaha is offline
post #9 of 10 Old 08-29-2013, 09:07 PM
SubaruB4's Avatar
Quoted: 31 Post(s)
Liked: 30
I use 3M Dual Lock and 3M VHB tape but for a projector I would not really trust it
SubaruB4 is offline
post #10 of 10 Old 08-30-2013, 05:09 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Simple logic says NO.
3M tech support say NONE of of there adhesive mounting tape is tested or approved from horizontal ceiling mounting as gravity is a constant and the product will fail. I had asked this about using the mounting tape to hold foam core panels..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
