Twin Ben Q 1080St's in a dual gaming setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2013, 07:02 PM - Thread Starter
Nooooob's Avatar
Hi all
The new Ben q 1080st has caught my eye in terms of price and reviews. I am going to get one purely for use as a home theater/xbox entertainment unit.
I am also going to be building a gaming PC and have become intruiged as to whether I can have some kind of "eyefinity"/dual projector setup for games using two of these babies without having issues with a seam down the center of the FOV.
I was originally going to get 3xLCD screens and do an eyefinity setup however something tells me that I may be able to get the same effect across a larger surface using only two short throw projectors.
Any thoughts?
Cheers
Nooooob is offline
post #2 of 4 Old 07-05-2013, 07:23 PM
tigerfan33's Avatar
Quoted: 358 Post(s)
Liked: 169
I don't think you could pull this off with this projector since there is no lens shift.
tigerfan33 is online now
post #3 of 4 Old 07-05-2013, 07:32 PM - Thread Starter
Nooooob's Avatar
Thanks for your reply.
So it is possible?
Hmm...time to delve back into those projector reviews.
Nooooob is offline
post #4 of 4 Old 07-06-2013, 09:24 AM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
I don't see why it wouldn't be doable. Read this thread http://www.avsforum.com/t/1391820/triple-screen-gaming-movie-setup. It should give you a starting point for research.
Sonyad is offline
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
