Whites are too hot! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-17-2002, 06:43 AM - Thread Starter
jxm71's Avatar
After running a few movies to test different scenes, the whites of the movie are just too bright. I have reduced the brightness through PowerDVD and the projector. Nothing seems to bring it down. The projector is an Infocus LP340B and I am using PowerDVD ver 4 on an HTPC. Is anyone familiar with other setting or filters I might be able to try?
"If left alone, I will take it apart"
jxm71 is offline
post #2 of 4 Old 06-17-2002, 08:17 AM
Alexander's Avatar
The "contrast" control reduces white level, "brightness" controls black level.
You could also try adding an ND2 (neutral density 2) filter. I don't know what size is appropriate for your projector, but make sure to get a multicoated one. People on the forum seem to like Hoya for some reason. :)
Alex
Alexander is offline
post #3 of 4 Old 06-17-2002, 08:33 AM - Thread Starter
jxm71's Avatar
Great. Thanks for the info. Is there a site I could order the filter from?
jxm71 is offline
post #4 of 4 Old 06-17-2002, 04:05 PM
catullus's Avatar
I had the LP350 for a while and sent it back because of the hot whites. Too bad, because the 340/350 projectors are otherwise excellent products. When I bought mine, two years ago, there wasn't nearly as much forum info on how to tame hot whites or control blooming.
I could eliminate the hot whites by fiddling with contrast and brightness, but at the expense of shadow detail.
Try the filter approach. It might help. Good luck with your quest.
Mike
catullus is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
