Bare Bulb replacemnet for Benq W1070 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #31 of 289 Old 03-19-2014, 04:35 PM
OZReddog's Avatar
Liked: 32
Originally Posted by hotjt133 View Post
So from your link it appears the E20.8 (OSRAM P-VIP 230/0.8 E20.8) is an OSRAM part no and they are cheap, while the 5J.J7L05.001 is a Benq part no. It is reasonable to guess they are the same OSRAM bare lamp.
However it looks like there is high chance that many $55-$65 OSRAM lamps on aliexpress are fake (as experienced by Capzor, even the seller vaguely admitted it), while the $80-$100 Benq lamp might be genuine (your experience). But the seller link from where you purchased has no feedback (BTW it is $81 now).
I think you are correct in the first instance re the Osram vs Benq part numbers. But .... I believe you are wrong regarding the fake nature of the cheaper Osram parts. Capzor appears to have unfortunately struck a rogue seller or there was an inadvertent substitution as the seller does say they have 'original' and 'compatible' lamps. I believe that Capzor was supplied a 'compatible' lamp when he actually purchased and paid for an 'original' one. The seller he used does NOT say original in the cheaper listing and does not show the 'Osram' labeling on the back of the lamp in the listing. ALL the other sellers when listing the 'E20.8' lamps go to the trouble of showing the back of the lamp and 'Osram' and the part number are clearly visible.
The way to look at it is perhaps to think of car parts. If you go to GM and ask for part number 12345 as a genuine part then you will pay say $40, but if you get the part from another supplier (not GM) then the exact same part will only cost say $29. Both parts have the same part number printed on the back but GM have a different call number for that part. If you look at the backs of the ' E20.8' and the '5J.J7L05.001' they are the same. It is just that Benq refer to the 'E20.8' as a part number '5J.J7L05.001' and consequently as you are being supplied a 'Benq' part you are charged more than the same 'Osram' part.
My lamp is exactly the same as the ones shown under the E20.8 search, with the exception of those from 'Discount projector lamp store'. These do not have the Osram brand showing and appear to be the one supplied to Capzor, i.e. a compatible lamp. I think there are better suppliers. I have found that 'feedback' means little in some cases as I left feedback for the seller I used but it is not there now. I was very happy with the service and the part I received. I think that if you purchased the lamp via this seller you would get the correct part but, as I said before I am an end user like you and, this cannot be guaranteed.
http://www.aliexpress.com/item/Original-OSRAM-P-VIP-180-0-8-E20-8-Projector-Lamp-Bulb/1222872408.html
OZReddog is offline
post #32 of 289 Old 04-05-2014, 07:51 AM
Capzor's Avatar
Hi guys,
Update on the compatible lamp issue:
The seller has refunded 50% of the cost of the lamp, which overall makes it quite cheap.
I have installed the compatible lamp and it actually works perfectly so far, I have over 60 hours on it.
The brightness, uniformity and color are all as i would expect. I suspect that it would have a lower lifetime however...
I will buy another lamp on aliexpress in the future, with some care to get an original wink.gif
Have a great weekend!
Capzor is offline
post #33 of 289 Old 04-05-2014, 09:49 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Originally Posted by OZReddog View Post
I have just done a brief search on Aliexpress searching for 'E20.8' :
The bare bulb used in the official housing (at least mine) is:
Osram P-VIP 240/0.8 E20.9n
That first numerical bit is the rated Wattage of the bulb: I don't think I'd recommend using any bulb rated 230W in a projector designed for 240W!
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #34 of 289 Old 04-05-2014, 09:54 AM
Capzor's Avatar
Same model number is on the original bulb my PJ shipped with as well.
I was considering getting my mitts on a higher wattage one for extra brightness, but it seems like a really dumb thing to do ;)
Capzor is offline
post #35 of 289 Old 04-05-2014, 05:37 PM
OZReddog's Avatar
Liked: 32
If you actually look at the variety of the lamps under the search some are 180w, some 230w and some are actually 240w so if this is a concern then simply read the description ..... Here is one example of a 240w (note: I am not endorsing this seller but simply using them as an example):
http://www.aliexpress.com/item/Original-projector-lamp-OSRAM-P-VIP240W-0-8-E20-8-Benq-5J-J7L05-001-for-benq/1713086009.html
No one is forcing you to purchase, some of us were looking for alternate sources of the lamps to save some money and chose to share the information on here. Personal choice in action.
Hi Capzor, sounds like a reasonable result overall. Pity you were unlucky to strike a dud seller. I hope the lamp works out well, seems like it ended up being a good price with the refund.
OZReddog is offline
post #36 of 289 Old 04-05-2014, 06:51 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Agreed; actually I was one of the earlier posters to this thread; looking for a spare without being ripped off; same as you guys.
TBH I mention the wattage since my first bulb order (which I arranged as an import via a local AV shop in my area) was supposed to be 'OEM', but in fact, they delivered this very bulb (OSRAM P-VIP 230/0.8 E20.8). Was an original Osram and in perfect condition; but it's simply not the correct bulb smile.gif
Since BenQ's web site clearly states that the intended bulb is 240W (on the spec list, here), the supplied bulb was simply just not 'OEM' (however loosely suppliers use the term smile.gif ); so the store had no problem requesting a return to swap it out for the correct bulb (which I'll be receiving in the next week) at no extra cost.
Best case the 230W bulb might've worked fine (maybe the same brightness; but likely dimmer); but pumping an unintended amount of power through a bulb is generally a good way to shorten it's lifespan. On Osram's own spec sheet, they explicitly state that:
P-VIP lamps are perfectly matched to the system design of the projector, e.g. the cooling set-ups, driving modes and ignition parameters.
Also with systems like Smart-Eco, the projector's lamp-ballast circuitry keeps quite a tight level of control on the amount of current flowing through the bulb to modulate brightness; so I suppose we wouldn't want to risk damage to that either.
My point I guess, is that if the intention is to get as close to the original bulb's performance as possible, it makes sense to request the bulb by exact model number. It's not fool-proof (counterfeits; changing model numbers; etc are all still possible); but at least it's one step closer.
post #37 of 289 Old 04-29-2014, 09:18 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
So after a swap-out, the local shop provided pretty-much the same bulb as Capzor received (as per here).
It's almost exactly the same as in Capzor's images, except the tip is correct when compared to the original; and it doesn't have the iffy connection to the base. Like Capzor's, the base also lacks a coil. That bothers me since I'm wondering what the coil is for. Hopefully nothing safety related wink.gif
I disputed and got a discount from the store that leaves me willing to risk keeping it, so I was happy to hear about this:
Originally Posted by Capzor View Post
Hi guys,
@Capzor, I'm guessing yours hasn't popped quite yet (hopefully!)? If your mileage has been good, I'll happily keep it. If not... well, I'll probably keep it anyway since I just don't have the time and patience for another return! smile.gif
Capzor likes this.
post #38 of 289 Old 04-29-2014, 09:42 AM
Capzor's Avatar
Hi kreeturez,
The bulb is going strong, no sign og dimming, flicker or anything untoward smile.gif
I use the projector heavily, at least 4 hours a day.
Just to be on the safe side though, I always use the lower lamp power setting and I always have high altitude fan on to keep it cooler.
kreeturez likes this.
Capzor is offline
post #39 of 289 Old 04-29-2014, 09:49 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Nice; thanks for the feedback!!
When I do replace my current bulb, I may pass on High Altitude - waaaay to noisy for me!
I guess I'm keeping it!
Thanks again!
post #40 of 289 Old 05-04-2014, 10:06 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
It is interesting that these
I would think that the 230W bulb is really not much different that the Benq 240W bulb. The 240W lamp seems to be the same as the 230W lamp except with the Benq numbers. If you are using Eco or Smart eco there should be no problem using the 230/0.8. E20.8 vs the 9. The only difference might be that the 240W bulb might last a little longer on High Mode but only time will tell. I would also bet that Benq had Osram put special numbers on their bulb so that it could sell for a higher price. With the big price difference it just might be worth taking a chance.
rwestley is offline
post #41 of 289 Old 05-04-2014, 10:28 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Not sure... SmartEco is as bright as Normal mode on bright scenes so I'm guessing 240W hits the bulb on a regular basis, even in SmartEco...
When I compared the two, they didn't look exactly the same either to the naked eye.
But TBH, the 230W bulb I received was an original Osram whilst the 240W that me and Capzor got weren't: so in the end, we're taking the same risk now in any case smile.gif
If anyone's received the 230W Osram and felt brave enough to try it, contributing first-hand experience here would be useful - maybe (other than lamp life) all is, indeed, good (and brightness is the same)?
The last thing to consider is the old 'Return on Investment': with users now reporting in excess of the claimed 6000 hours on their original bulbs, there's certainly an argument for 'bang-for-buck' on original lamps: yeah, the price difference is $100 or so - but if that buys 5 years of trouble-free use, it might just be worth it...
post #42 of 289 Old 07-12-2014, 06:31 PM
JonnyVee's Avatar
Quoted: 164 Post(s)
Liked: 120
Purchased a bulb from this seller.
http://www.aliexpress.com/item/Origi...&af=cj_6155355
Works great so far and quality looks good. The only thing I noticed is the OSRAM writing on the back is stamped or etched in rather than printed on.
ID:	158329   Click image for larger version
ID:	158337   Click image for larger version
ID:	158345   Click image for larger version
ID:	158353   Click image for larger version
ID:	158369   Click image for larger version
JonnyVee is offline
post #43 of 289 Old 07-13-2014, 03:26 PM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
Looks legit. It is the same etched lable as someone purchased from an Australian site.
http://forums.whirlpool.net.au/archi...9666#r43458700
This, however differs from the photos on the Aliexpress site. It could be Osram changed packaging recently.
hotjt133 is offline
post #44 of 289 Old 07-13-2014, 03:28 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Very possible...
It's also more difficult to remove/tamper with an etched label than it is with a printed one.
post #45 of 289 Old 07-23-2014, 08:50 AM
Capzor's Avatar
Thanks JonnyVee, very helpful info and great to have pictures of the product, valuable info for many.
In relation to the "compatible" lamp which i'm using, it's still going strong, no problems at all after 1300 hours usage.
Capzor is offline
post #46 of 289 Old 07-23-2014, 08:56 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
That's rather encouraging, thanks for keeping us posted... You're using it in Eco, right? (Does it work correctly with the variable brightness that SmartEco provides?)
post #47 of 289 Old 07-23-2014, 09:01 AM
Capzor's Avatar
I haven't used smarteco, much, i just tested it for 5 mins and it worked ok. but i have been using it in high lamp mode for a while now to get the extra brightness for 3d stuff i'm happy with it especially considering i ended up paying almost nothing for it. If it shows any weirdness though i intend to swap it out immediately.
Capzor is offline
post #48 of 289 Old 07-25-2014, 03:57 AM
JonnyVee's Avatar
Quoted: 164 Post(s)
Liked: 120
My pleasure. Two weeks going and the bulb is ok. Nice and bright and color looks great. I'll be keeping this one in and the old 2000 hr bulb will become a back up.
I'm not using Eco or smart Eco anymore either. Nice to have the extra brightness ... Don't mind replacing the bulb each year for $80.
JonnyVee is offline
post #49 of 289 Old 08-17-2014, 03:28 AM
desann's Avatar
Quoted: 37 Post(s)
Look like original!
I have exactly the same bulb in my W1070 even without printed OSRAM writing. Its an original bulb which came with PJ, never been replaced.
desann is offline
post #50 of 289 Old 08-17-2014, 04:47 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Originally Posted by desann View Post
Look like original!
Interesting! It's probably like I thought above, where they've replaced the old model-number/manufacturer sticker with etching to prevent it from being easily scratched out and removed/replaced.
Incidentally, early models of the W1070 often had poor brightness uniformity.
This seems to have improved a lot with new models (I've seen this myself - my replacement model is very uniform) - and there were theories that it might've been lamp related (twisting the orientation of the old lamp shifted the non-uniformity).
It's possible BenQ addressed this with a revised lamp: maybe Osram changed the design a bit to improve this. If I opened my new one up, it would probably have the new-style lamp as well...
post #51 of 289 Old 10-13-2014, 06:20 PM
Liked: 0
Hi man.
I also have a Benq W1070 and seems that I have the same problem that you have. The lamp is 780 hours. Last two days, after less than 2 hours of playing PS3, the projector blanked out (the game was still playing and sound coming out of amp), after half a minute the lamp LED showed red.
So I want to ask you if you could solve that problem or if you had to change the lamp, as that may help me solving my problem.
Aragorn646464 is offline
post #52 of 289 Old 10-13-2014, 06:27 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Originally Posted by Aragorn646464 View Post
Hi man.
The lamp (assuming it's an original) should last way longer than that. Reports of thousands and thousands of hours is common. If it powers back on after switching itself off, then it's unlikely the lamp. (If it won't power back on, then it could still be the lamp.)
I have a colleague who had the exact same thing and it turned out it was actually over-heating. Make sure the projector is ventilated on all sides (no close obstructions; especially around the vents) and that your room isn't running too hot.
(Also if you're at High-Altitude, you might want to try switching on High-Altitude mode - but it's noisy!)
If none of the above, then perhaps contact BenQ.
post #53 of 289 Old 10-13-2014, 08:29 PM
Liked: 0
Thanks kreeturez for your reply .
(The lamp is the original one that came with the projector).
The projector powers on normally after switching itself off (the brightness and the color are normal after restart it).
Currently, the projector is well ventilated, because it is mounted on a universal mounting in the roof, but I sense that the room is running pretty hot.
I live in Bogota, so I must to have the High Altitude mode always on, but the normal mode and the high altitude mode have the same noisy level, is that normal? or I have to notice that the High altitude mode is noisier than the normal mode?
So probably the room is running hot. I´ll try to ventilate it a little more (maybe an air conditioner?).
* Sorry if I have grammatical mistakes
post #54 of 289 Old 10-14-2014, 11:54 AM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Your English is just fine :-)
At 2500m above sea level, you definitely need to be running in High-Altitude mode (the threshold is 1500m!). Alternatively you need to make sure your room runs cool (A/C would definitely do the trick).
Are you running under SmartEco?
I did find that under older firmware versions (before version 1.08), HA-mode was being ignored under SmartEco lamp mode. This was fixed in 1.08 (more info here: BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ ) And in this case, fan noise was indeed the same with it both on and off - just like you. So if you're running in SmartEco this could be your issue.
You could try swapping to another lamp mode (Eco or Normal - which should have HA Mode working OK). Updating your firmware would help as well if this is the case.
post #55 of 289 Old 10-15-2014, 05:02 PM
Liked: 0
I always running in Smart Eco mode and I notice that my projector is 1.07 firmware version.
I just switched the mode to Normal and I saw no difference in the image quality, but now I notice that the fans are running louder than before, so I suppose that the High Altitude mode is working correctly now.
Today, the projector was working for 5 hours and no switch off itself , but the A/C is the next step (My dad is an A/C retailer, so I think that is no problem :P)
Thanks for all kreeturez, I appreciate all that you did for me
post #56 of 289 Old 10-20-2014, 11:54 AM
tyee's Avatar
Quoted: 69 Post(s)
Liked: 29
Just received this as posted above - aliexpress bulb. Will install it today. Has printed OSRAM info, not etched. My lamp is over 5500 hours, I guess I should replace it?
tyee is offline
post #57 of 289 Old 10-20-2014, 12:13 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Pleasure man - glad you're sorted!
5500 hours. Nice. What lamp mode have you been running? Bright SmartEco? Or dimmer Eco?
In either case, yeah: I think at 5500 hours you should notice some extra brightness with a new lamp. And since the SmartEco rating is 6000 hours, you're reasonably close to rated life so this is probably a good time to swap over.
As for the bulb itself: some are printed; some etched. It looks like more recent ones are etched (but my original bulb was printed like yours is). Seller (and item) rating is good so hopefully you snagged an original - though it's always roulette
post #58 of 289 Old 10-20-2014, 12:27 PM
tyee's Avatar
Quoted: 69 Post(s)
Liked: 29
I use ECO only since the beginning. Slightly reduced brightness is ok, I have a dedicated room. I tried Smart ECO for a while but actually saw variations in brightness as I viewed and that really bugged me.
tyee is offline
post #59 of 289 Old 10-20-2014, 02:04 PM
tyee's Avatar
Quoted: 69 Post(s)
Liked: 29
Ok, I'm viewing avsforum on the new bulb. Wow, what an increase in brightness, even on ECO! Very nice.
I will add a couple of things when replacing the bulb. I removed two stickers on the new bulb with those codes written on them. The original bulb did not have those on, although I could see where one had been removed. I think they are just paper stickers and I wouldn't want them to catch fire because of the hot bulb but really, do they need to be removed??
When replacing the bulb there is a outward tit on the edge of the glass only in one spot. It must fit in the notch in the metal piece that holds that particular side in place. I didn't see this mentioned yet. It is important. Do not screw the screws that hold the metal supports down too tight initially or you may have a hard time getting the bulb sitting correctly in the mount. Oh, and don't forget to put that piece of plastic back on for dust protection before replacing the cover.
Oh, yes, the replacement bulb is identical to the original. I may order another!
tyee is offline
post #60 of 289 Old 10-20-2014, 02:14 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 387
Thanks for sharing! I've noticed the stickers on the original as well. Mine had literally disintegrated; so no harm either way.
Told you you'd appreciate the boost in brightness
Here's to another long-lasting lamp!
Benq W1070 3d Ready Dlp Projector 1080p Hdtv
