BenQ W1070 -vs- Optoma HD81-LV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-14-2013, 01:12 AM - Thread Starter
apxltd's Avatar
It looks like my Optoma HD81-LV is experiencing the death by blue screens (documented here), and thus it's time for a new projector. Good riddance. Like many on that thread, it's my 6th Optoma in 3 years.
After a bit of research here, it seems like the BenQ W1070 is favored by many... and it seems pretty similar from a specs standpoint. The BenQ has 2000 lumens where as my HD81-LV has 2500, but otherwise they have same contrast (10k:1). The BenQ has 3D, though I'll never use that. So, aside from the 500 lumens, what am I going to miss?
I know very little bit about projectors, but the W1070 seems much less expensive; I paid ~$2500 for my Optoma in 2010. Did stuff get cheaper? Or, will I be disappointed?
apxltd is offline
post #2 of 7 Old 07-14-2013, 05:40 AM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
You haven't given us enough info to make a recommendation...
Depends what your primary use is, for movies a B-STOCK JVC RS-46 is better IMO, but these cost around $2000 I believe.
If you want to stick with a DLP, the w1070 is a decent choice, but it depends what you are going for. The Sharp XVZ-30000 will have better contrast and better 3D (albeit not as bright), so also depends on your screen size and placement flexibility.
http://www.avsforum.com/t/1435626/benq-w1070-dlp-full-hd-3d-ready-with-lens-shift-for-1000/5310#post_23478413
Access HERE from this thread
coderguy is online now
post #3 of 7 Old 07-14-2013, 09:18 AM - Thread Starter
apxltd's Avatar
Thanks. It's in a darkened theater room, used for movies, occasional TV, and rare gaming. I'm not sure what the screen size or distance is, but I think 100" and 14ft.
Is three years an average life span for projectors? I didn't expect to replace one so soon, which is why a cheaper one is more appealing.
How would you suggest I compare the Jvc and benq? Buy both, and return one?
apxltd is offline
post #4 of 7 Old 07-14-2013, 09:21 AM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
If this is mainly for movies, well I can tell you that as long as you get a good JVC sample, then there is really no comparison overall, you will like the JVC better I think.
I would give AVS a call (Sponsor of this forum), send Mike@AVScience.com an email first and find out what B-Stocks or Refurbs they have in-stock for a JVC.
For movies, the JVC > others I have seen (and I've seen a lot)...
Sometimes AVS had some B-Stock HD-250's in around $1300 I believe, that is a heck of a projector for that price, and still comes with 2-year MFR warranty.
If you buy a newer JVC, like the RS-46, I would think you might get 5 years out of the unit, heck maybe 10, just depends partly on luck and stats. There is no exact number of how long a projector can last, though DLP's do tend to last longer sometimes (but not always).
post #5 of 7 Old 07-14-2013, 11:35 AM
Mrke1's Avatar
Quoted: 22 Post(s)
Liked: 35
I can tell you right now the w1070 will not throw 100" at 14ft. It'll be closer to 9 or 10ft. I agree that you should look at the JVCs if you can swing it.
Mrke1 is offline
post #6 of 7 Old 07-14-2013, 12:48 PM - Thread Starter
apxltd's Avatar
Ah shoot; I just measured the projector space. Looks like the RS-46 won't fit :-(
It's a 16.25Wx17D shelf box, and it's not quite feasible to expand. The throw distance is 14.5' (+/- 6", hard for me to measure), and the screen is 80" x 45.5", which is 92" diag if my trig knowledge serves me right.
Playing around with a throw calculator, I now understand what you mean about not throwing. It looks like the BenQ W7000 (which does seem to be able to throw) is a tad too wide for the box...
Ugh. Any other recommendations?
apxltd is offline
post #7 of 7 Old 07-15-2013, 10:06 AM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 116
The new Optoma HD25 or HD25-LV would seem like natural choices, given your previous projector.
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is offline
Benq W1070 1080p 3d Projector , Sharp Xv Z30000 Dlp
