how portable are projectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-15-2013, 02:45 PM - Thread Starter
drew4452862's Avatar
I want to bring something like the optoma hd25 or currently looking for one under 2000. Will the projector break on long card rides? thinking 4 hours, in the ac. prolly boxed between 2 pillows or something else that would be safe
drew4452862 is offline
post #2 of 2 Old 07-15-2013, 04:22 PM
AV_Integrated's Avatar
Quoted: 993 Post(s)
Liked: 728
People travel with projectors all the time. Heck, they are shipped on the slow boat over from China, then UPS'd right to your door. Not likely they are using pillows along those joy rides.
As long as you take some care with their transport, they will do fine. Heat/cold will not affect a projector very much when it is not actually on. Just give it a couple of hours to acclimate to the place where you finally end up using it.
For example, if you leave it in your car and your car is 100+ degrees out in the sun, don't bring it into the A/C home and turn it on right away. That could hurt things. If you give it a few hours, you won't have any issues. Same is true in reverse. Fine to leave it in a car when it is 10 degrees outside, but inside your 70 degree home, give it a few hours to warm up before you turn on the projector.
drew4452862 likes this.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Optoma Hd25 Hd 3d Home Theater Projector
