. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-21-2013, 04:48 AM - Thread Starter
brekke's Avatar
brekke is offline
post #2 of 3 Old 07-21-2013, 08:45 AM
urbeenjammin's Avatar
Quoted: 66 Post(s)
IF YOU CAN GET THE HD25-LV,JUST GET THAT SINCE IT IS AT 3200 LUMENS.
urbeenjammin is offline
post #3 of 3 Old 07-21-2013, 09:34 AM
gwlaw99's Avatar
First, make sure that the people tor will throw the right size image from the distance you want. Make sure it will be the height that you want on the wall. The HD25 is a bright projector and will be more than bright enough for a dark room. A projector can be too bright which could hurt black level.
Use the calculator here for size, position and brightness.
http://www.projectorcentral.com/Optoma-HD25-projection-calculator-pro.htm
gwlaw99 is offline
