Picture cut off - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2013, 06:40 AM - Thread Starter
Swentod's Avatar
Hi everyone. I am new to the forum. I have been connecting a couple computers to my projector. It is an optoma hd3300. I have been using a VGA cable to connect. The picture is cut off on the top and bottom. I have tried to change the resolution, nothing seems to work. Is there a setting somewhere or a driver I need to download to make the whole screen visible on my projector? Thanks! Let me know if you need any additional info.
Swentod is offline
Old 07-21-2013, 08:47 PM
jnabq's Avatar
Liked: 39
Did you change the resolution/aspect ration on the pj, or did you try changing the resolution output on the video driver? Some people might be able to help more if you tell the type of video card your using as well?
jnabq is offline
Old 07-23-2013, 06:37 AM - Thread Starter
Swentod's Avatar
Yea I've changed the picture ratio on my projector, but it only has two settings superwide or 4:3. I have gone one by one on the computer and tried resolution changes. Any other ideas? Graphics is just intel integrated graphics, GMA 3100. Any help is appreciated. Also I will be upgrading soon. I will post over in the HTPC section for video card suggestions. Thanks got any help.
Swentod is offline
