How many feet/Lumen fL is 'too much' ? Considering new Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-29-2013, 10:14 AM - Thread Starter
Miwo's Avatar
i have been using the projector calculator at Projector Central and have been considering the Optoma HD25,HD25e, and BenQ 1070. Right now I have a Viewsonic PLED-W500. I have an 85" Da-Lite CinemaVision 1.3 gain fixed screen in my living room. My living room is open with my kitchen, which has some windows that I dont block out. Generally poor lighting during daytime, fine during nighttime
I got these fL numbers from the calculator:
HD25e: 85fL, 9'3" distance
HD25: 61fL, 9'3" distance
w1070: 49fL, 9'3 distance
PLED-W500 (current): 27fL, 8'8" distance
I find my current projector only usable during nighttime and early morning. I am assuming the calculator goes by advertised lumens. If I were to run the HD25/1070 in Eco mode (say 60% of advertised lumens), it would still put me at 40-60fL. I
Is there such a thing as too much feet/lumen?
Miwo is offline
post #2 of 4 Old 07-29-2013, 11:17 AM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
During the daytime, there is almost no such thing as 'to much light'. But, at night there certainly is. I run the W1070 in low brightness on theater mode using a 161" screen and it is plenty bright enough. So, about 15-18 lumens per square foot is more than sufficient for after dark viewing.
But, during the day, the only hope you have for any usable image is by putting up lots of lumens. I think you would be pretty happy with the W1070 or the 25LV in your setup.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 11-02-2013, 08:31 PM
Bob Ray's Avatar
IN HIS REVIEW OF THE BENQ W7000, BILL LIVOLSI WROTE: Our measurements indicate that 3D mode puts out 1100 lumens on our test sample, and BenQ's 3D glasses transmit 28% of the total light they receive. If you have a 1.0-gain screen, that works out to 11 fL on a 100" diagonal screen. I'VE GOT A 120" SCREEN. DO THE MATH AND THAT SEEMS TO KNOCK THE fL down to 7.5. IS THAT GOING TO BE GOOD ENOUGH IN A VERY LOW AMBIENT LIGHT? IS IT EVEN ENOUGH IN A TOTALLY DARK ROOM?
Bob Ray is offline
post #4 of 4 Old 11-03-2013, 03:36 PM
augiedoggy's Avatar
please drop the caps... its considered as yelling in a forum.
That going to be a pretty dim picture in my opinion.
augiedoggy is offline
Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector , Optoma Hd25 Hd 3d Home Theater Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Viewsonic Pled W500 Dlp Projector
