shelf mounting for HC4000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-29-2013, 03:17 PM - Thread Starter
Babar Cheema's Avatar
I have HC4000 projector and have shelf mounted it at a height where projector is in middle of display screen. As there is no lens **** available so I have manually uplifted rear of the projector and now display is perfect.
I want to know is this safe to position projector with it rear side a little bit higher then front side?
Babar Cheema is offline
post #2 of 2 Old 07-29-2013, 03:42 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
It's safe, but a very bad idea. This means you have to use a lot of keystone correction to fix the image shape.
Jim McC is offline
Mitsubishi Hc4000 300 Inch 1080p Front Projector
