Projector <2000 for theater (w/ good black levels) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-31-2013, 09:17 AM - Thread Starter
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 29
I am in the process of choosing a new projector for a dedicated theater room (although it will also be used for some gaming). Because it is in a basement with very little light, a projector that excels in black levels is preferred. One projector that I kept coming back to was the Epson 8700UB- although a bit older, it is supposed to have excellent PQ. Others I was looking at were the Panasonic PT-AE4000U, Epson 3020, and Acer H9500BD. Are there any other new ones to consider in the price range that can match the 8700UB? Thanks!
avfanatic1 is offline
post #2 of 8 Old 07-31-2013, 09:30 AM
BllDo's Avatar
Quoted: 574 Post(s)
Liked: 373
If you could push that two grand a little, you could look at one of these:
http://shop.avscience.com/JVC-DLA-RS4800-B-stock_p_564.html
BllDo is offline
post #3 of 8 Old 07-31-2013, 11:34 AM - Thread Starter
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 29
I think that will be too much. I really should have said like under $1700. Basically what the question comes down to is it ok to get a few year old projector for supposedly better blacks or are there other advantages of the newer projectors (ie Epson 3020) that make getting one from 2010/2011 not worth it.
post #4 of 8 Old 07-31-2013, 12:34 PM
BllDo's Avatar
Quoted: 574 Post(s)
Liked: 373
Advantages of a newer PJ will be warranty, longer bulb life and possibly better tech (definitely arguable though). I'd try to stick to a relatively newer PJ.
Here is one that would fit the bill:
http://www.ebay.com/itm/JVC-DLA-RS45-REFERENCE-SERIES-2D-3D-D-ILA-PROJECTOR-w-REMOTE-/390635111362?pt=US_Video_Projectors&hash=item5af3aac3c2
AV_Integrated likes this.
BllDo is offline
post #5 of 8 Old 07-31-2013, 03:21 PM
AV_Integrated's Avatar
Quoted: 983 Post(s)
Liked: 725
The JVC RS Series will blow away about any other product on the market for contrast in my experience. It simply is in a different class, and generally maintains a price point which is far higher than others.
If you are looking to really get a good deal, then that find seems to be pretty solid. It certainly is the projector which will deliver the most impressive black levels for the money which I have seen recently.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #6 of 8 Old 08-01-2013, 02:40 PM
Quoted: 64 Post(s)
What's the B Stock mean?
tbacos is offline
post #7 of 8 Old 08-01-2013, 03:15 PM
Robert Clark's Avatar
Quoted: 49 Post(s)
Liked: 47
That one is used with no warranty so be careful...
Robert Clark
Robert Clark is offline
post #8 of 8 Old 08-01-2013, 05:52 PM
BllDo's Avatar
Quoted: 574 Post(s)
Liked: 373
B stock can be factory over runs, factory refurbs, slow moving stock...quite a lot of different things.
Give Craig Peer a call and he can fill you in on the specifics of this one:
Craig Peer, AV Science Sales. Direct Line - 585-671-2972
BllDo is offline
Epson Home Cinema 8700 Ub Projector , Acer H9500bd 3d 1080p Home Theater Projector , Panasonic Pt Ae4000u 1600 Lumen Lcd Home Theater Projector
